    Results 1 to 9 of 9
      13" 2 piece rotor source
      OK I searched the archives, found a few links but no real results....
      So,
      Does anyone know where to get 2 piece 13" x 1.25" rotors?
      I'm pretty sure I'll have to get custom hats made, but there has to be a place to get rotors!
      TIA
      Keith
      Prescott Arizona
      Well, there's these guys, but they're not cheap! You could probably find something at Coleman racing.
      Brian D
      Snotty Bimmer driver.
      Jul 2003
      Anaheim Hills, CA
      Willwood sells a ton of different 2 piece rotors.. might want to check them out as well.. I know they make the rotor part (well, Im pretty sure)
      Worth a shot..
      1968 Track Rat Camaro:
      Medford, OR.
      Quote Originally Posted by 427v8
      So,
      TIA
      Keith
      427v8,
      I have seen you make comments that we could not help you out last time you checked with us. Maybe we can help here...and forget about the past. Hey, were all in this together (to help one another), the 13"x1.125" rotors you seek make up about every kit we sell. I have them on the shelf and would custom build the hats you want to your specifications. Plated, heat-treated, directionally veined.....8 on 7.00 " mounting. PM me and I'll give you pricing on both the "custom hats" and the rotors you seek.
      Laramie Torres
      Thanks Laramie!
      The person I talked to didn't want or wasn't authorized to sell parts, just kits, which I guess I can understand. To their credit they did offer to look through the overstock etc to see what they could find rotor wise...
      I'll IM you later with the hat dims, it's all at home right now.
      Keith
      Oct 2005
      SoCal
      Getting the rotors is easy, just have to find the right offset hats and such. I have a set of drilled and slotted baer eradispeeds in that exact size, they work very well.
      Well hats can be had from Coleman, custom, rotors I'd like to be an off the shelf item...
      So did you just order the rotors from Eradispeed.com or something??
      Oct 2005
      SoCal
      Got them from a friend who is a baer dealer, but mine aren't all that special, just off the shelf viper parts. Yeah we have the same bolt pattern and all that jazz, makes things nice and simple.
      do you have any pics of the adapters you made for your viper calipers to fit
