      May 2008
      LS7 Z28 Camaro Convertible
      I have an amazing 2002 Z28 Camaro Convertible that has had an LS7 from a 2006 Z06 installed into it. Up until recently GM had never seen fit to build a convertible Z06 with an automatic transmission, so I had it done. The car is amazing. It looks good, it sounds good, it passes OBDII inspections,it's reliable, and IT IS FUN TO DRIVE!
      Other than the following, the car is stock and unmolested.
      Engine: 2006 LS7 with less than 18K miles
       505 horsepower / 475 lb.-ft. torque
       Racing technology transfer takes production engine performance to new heights
       Racing-derived CNC-ported aluminum cylinder heads
       Each engine assembled by hand by a single, specially-trained builder
       Dry Sump converted to Oil Pan w/ Melling High Flow Oil Pump
       Nick Williams 90 mm Throttle Body
       Lingenfelter Performance Cam/Crank Converter Box
       Kooks 1 7/8" D Port LS7 headers
       Magnaflow catalytic converters
       Sweet Thunder chambered exhaust
       Passes State required OBDII Emissions Tests
      Transmission: GM 4L60E Stage II w/Yank 3000 RPM Torque Converter
      Exhaust: Custom Made Stainless Steel True Cat Back Dual Exhaust w/ Chambered Mufflers
      Suspension: Custom SLP Performance Bilstein/Eibach Shocks and Springs, and a Custom Made Panhard Rod
      Rear End: Custom Strange Engineering 12 Bolt
       Strange designed 12-bolt case with torque arm provision
       Premium nodular iron casting
       HD Strange/Eaton 33-spline posi unit
       Fully welded axle tubes
       Chromoly end caps
       Standard 33-spline axle
       1350 series yoke with u-joint
       Retains 4 channel ABS
       Chrome rear-end cover
       3.42:1 Positraction
      The asking price is $21,000.00
      You will be hard pressed to find another car like it. Cash is king and any reasonable offer will be entertained. Tire kickers need not apply.
      May 2008
      Here are pictures.
      Name:  Passenger Front Wheel.jpg
      Name:  Driver Rear Quarter.jpg
      Name:  Front Passenger Seat.jpg
      Name:  Driver Front Quarter.jpg
      Name:  Back Seat and Deck.jpg
      May 2012
      PM sent
      May 2008
      Soundclip
      Here is a link to a video made by the guy that put the engine in the car: https://www.youtube.com/watch?v=iH92-eHz7t4
      May 2008
      I neglected to include the location of the car. It is in metropolitan Milwaukee, Wisconsin.
