      May 2015
      Ring gear pattern help
      I'm building my first rear end, it's a 8.5" 10 bolt out of a 70s nova, I've set it up with a Detroit TrueTrac and a new Yukon 3.73 ring and pinion. Backlash is set to .007-.008 measured across multiple spots on the ring gear. This seems to be the best pattern that I can get. Can anyone's more calibrated eyeballs make a suggestion if this is acceptable or if they think I need to adjust the pinion shim? Thanks guys.
      Coast side:
      Drive Side:
      I think it looks pretty good. I would roll with it.
      Tony H.
      Sep 2012
      San Diego
      that looks good, button it up.
      71 maverick.
      71 comet in build process.
      i work at Current Auto Performance www.currentautoperformance.com. i also build the differentials for San Diego Gear and Axle.
      USA
      Looks Good
      Jeff Tate
      U.S.A.
