    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 122
    1. #81
      Sep 2015
      Rockvale TN
      Thanks guys - Don't know if I mentioned it earlier, but the rear-end was off center of the body by a 1/4" to 1/2". I was able to shift the rear into place evening up the gap in the wheel house's by loosening the body mounts.
      Peets - You will be in the sweet spot with 255 or 275 tires on the rear if you can source a 6" BS wheel...my 255's will be close on the outside lips with my 5.75" BS wheels. I'm speaking only for the '67...other years I can't swear to.
      Stay tuned for a major turn of events with this project shortly...
    2. #82
      Sep 2015
      Rockvale TN
      Street plans on hold for a bit...this one is going NHRA Stock Eliminator racing first. Street items previously installed are being removed and suitable track replacements taking their place. CM roll bar install is imminent...
    3. #83
      Sep 2015
      Rockvale TN
      Sep 2015
      Rockvale TN
      Roll bar installation should be completed this weekend. Tilt steering column from Jim at BirdsandBowties will be a nice addition...
    5. #85
      Sep 2015
      Rockvale TN
      I removed the electric clock in the dash cluster and replaced it with a voltmeter today.
      The mechanical water temp and oil pressure gauges will be going on the column as it is in the Camaro...
    6. #86
      Mar 2015
      why did you remove the ls1 brakes?
    7. #87
      Sep 2015
      Rockvale TN
      Quote Originally Posted by camarodude87 View Post
      Too large and too heavy...the Aerospace units weigh next to nothing even tho they are 4-piston.
    8. #88
      Sep 2015
      Rockvale TN
      Sep 2015
      Rockvale TN
      Indiana
      Looks like you're moving right along! Nice!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    11. #91
      Sep 2015
      Rockvale TN
      Self inflicted headliner install and filled the tailgate trim holes with stainless button head bolts w/nylon washers.
    12. #92
      Sep 2015
      Rockvale TN
      Front/rear glass installed and headliner finished.
    13. #93
      Sep 2015
      Rockvale TN
      Wow a lot of nice work sinse I checked in last time. Nice job on the roll bar.
    15. #95
      Sep 2015
      Rockvale TN
      Dadgummit...I had to go and try a little wet sanding this morning. It's such an improvement now I see I will have to do the entire vehicle...I'm tired already lol.
    16. #96
      Sep 2015
      Rockvale TN
      Having difficulties with the reveal moulding...got a pro coming tm to check it out. Slowly adding parts...
    17. #97
      Sep 2015
      Rockvale TN
      All glass, trim and bumpers installed finally.
    18. #98
      Oct 2010
      Mena, AR
      Looking good! How much shoulder room do you have with you roll bar? Just curious, I have a 67 Elky and have pondered a bar, but never liked the rear downbar out the rear window look. Never thought to move the hoop forward because of shoulder clearance.
      Chris
      Chris
      1967 ElCamino
      2004 Chevy SSR (my sons)
      1951 Chevy pickup(my sons)
      1967 Elky https://www.pro-touring.com/showthre...587-Evil-Angel
      1951 truck https://www.pro-touring.com/threads/...3-year-old-son
    19. #99
      Sep 2015
      Rockvale TN
      Quote Originally Posted by bmbrzmn101 View Post
      Chris
      I don't have an image on this pc Chris of the seat in after the roll bar install, but I'll post one next weekend for sure. There's at least an inch of clearance between the hoop sides and the sides of the bench seat. The swing-out door bar stubs will be killer if you arent used to them being there lol.
    20. #100
      Indiana
      Looks good Rich!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
