    Results 21 to 40 of 52
    1. #21
      Jun 2010
      Deployed
      Looking at this too.
      32V 400A Car Quick Release Fused battery Distribution Terminal Clamps Connector | eBay
      1970 Camaro/DSE build
    2. #22
      Nov 2018
      Either one would do the job. Whatever you use to should be able to pass an overcurrent for a short time like the second one states. Otherwise, it's going to pop every time you start as the starter pulls hundreds of amps for a short time.
      There really is no need for a fuse right on the battery though. The OEMs don't use one on the primary cabling and they don't really even do anything to protect it from chafing anywhere. Split loom and tie downs will keep the primary wiring from moving enough to chafe. I've never done more than use wire loom with proper tiedowns, and have never had an issue with it.
      When I relocate the battery on my project to the bed, I won't be doing anything more than I've done in the past. Welding cable, wire loom, tie it down every so often. Only, I'll be running the alternator to the starter lug, then using the wire from the starter to the battery to charge the battery. Welding cable sheathing is nearly indestructible.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    3. #23
      Celina, Texas
      Fuse for trunk battery
      I went with this relocation set up from CE Auto Electric Supply. This runs from the top battery post to a bulkhead at the firewall to power everything except the efi. The Terminator X power harness is by itself on the side posts.
      https://ceautoelectricsupply.com/bat...awg-and-2-awg/
      This is the side of the box. There’s a short cable connecting that top lug to the battery post. A long cable is attached at the bottom and runs up to the firewall.
    4. #24
      Jul 2019
      Ohio
      Quote Originally Posted by Vimes View Post
      Are you sure? I think these distribution blocks are fused, and are used in most of the newer GM vehicles
      https://www.amazon.com/Distribution-.../dp/B0DCBVL6KZ
    5. #25
      Jun 2010
      Deployed
      Like I mentioned, I think we have neglected to see what’s being done today in modern cars. It seems many cars now are fused at the battery.
    6. #26
      Nov 2018
      Interesting. Here is a nice discussion about it.
      https://electronics.stackexchange.co...uits-protected
      I then looked at the size of the battery cable on a Colorado and it looks like they've been put on a diet, which may be why they now use a fuse. Battery cables used to be a 0GA or 2GA, but (going by a picture) it looks like they're now more like or 8 gauge. So, what it boils down to here is while there's no real reason to run one, there's no real reason not to. You might also consider a circuit breaker, which blows like a fuse but can easily be reset.
      2v-24V-80-300A-Marine-Circuit-Breaker/dp/B074FGT36D" target="_blank">https://www.amazon.com/12v-24V-80-30.../dp/B074FGT36D
      2021 Durango R/T
      2005 Dakota beater
    7. #27
      Jun 2010
      Deployed
      The way I see it, most cases of a rare fault or short to ground happens it will burn down a disposable car. Not a big deal right? It’s insured, just collect the payout and move on.
      It’s a different game when it’s your classic car. In a way you want to accept the minimal risk as possible.
    8. #28
      Jul 2019
      Ohio
      Read this post
      https://www.camaros.net/threads/more...ost-1783368631
    9. #29
      Nov 2018
      That's a good way of putting it. Never let it be said I can't change my mind mid-stream.
      2021 Durango R/T
      2005 Dakota beater
    10. #30
      Jun 2010
      Deployed
      I’m putting something in line with the main cable like it or not….its just a gamble hoping you don’t chafe it!
      I just need to figure out what…I might also get the CB just to see how it likes the starts amp draw.
    11. #31
      Nov 2018
      No worries. But, a fuse and a circuit breaker will do the same job, so you only need one or the other. You can use a clamp on ammeter to find out what your starter draw is and size the fuse or circuit breaker accordingly.
      2021 Durango R/T
      2005 Dakota beater
    12. #32
      Jul 2019
      Ohio
      This is a nice breaker used in marine applications if you want a breaker instead of a fuse so you can reset it. The time+load to trip curves are available for each size and available up to 200amp. If you look at the curves, you should never be in a situation where you exceed 200amp trip time+load limit without a dead short. Easy to make a panel to install this in for a nice finished result too.
      https://www.invertersupply.com/index...ucts_id=185310
    13. #33
      Nov 2018
      Nice looking. Question, does anyone know if there is an amperage difference on what a circuit breaker rated for 48V will pass on a 12v circuit? Math says the circuit breaker should handle 4 times more amperage on 12v as 48V, since the wattage would be the same, but I don't know if a circuit breaker only looks at amperage or voltage, or both. My google-fu indicates that the amperage may be the same regardless of voltage, but that doesn't seem right.
      2021 Durango R/T
      2005 Dakota beater
    14. #34
      Mountain Springs, Texas
      It’s strictly based on current. It does not vary with voltage. The circuit breaker doesn’t have a ground connection so it has no way to sense the voltage.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    15. #35
      Texas
      How about a shutoff via Bluetooth. That way the shutoff could be located a little more remote (or hidden). Use a key fob to turn it on or off.
      -Bob (66 Nova)
    16. #36
      Jun 2010
      Deployed
      Quote Originally Posted by BBPanel View Post
      Nice feature, but the intent would be for an immediate disconnection rather on demand.
    17. #37
      Nov 2018
      Appreciate it.
      2021 Durango R/T
      2005 Dakota beater
    18. #38
      Jun 2010
      Deployed
      Quote Originally Posted by srode View Post
      How do you read the time-load chart? It seems it takes about 1.5 sec to start my car hot, about a 1.25 cold. How many amps can it handle for that amount of time?
    19. #39
      Jul 2019
      Ohio
      In the chart at the bottom of this page for the 200amp breaker, the red zone is the trip zone with the time to trip across the bottom of the graph and the % rated load on the side. As an example, on this model it takes between 10 and 40 seconds to trip at 200% of the rated load, which would be 400amps drawn.
      https://www.bluesea.com/products/704...nel_Mount_200A
      So you want to calculate your max load and max continuous load and and use the larger of the 2 to decide on which size you need. A starter isn't likely going to trip the breaker unless there's something wrong with it it most cars because the start cycle is so short and most people aren't going to let a starter spin for longer than 10 seconds anyway and will let it cool before trying again. Big cooling fans+AC+ECM+lights+Stereos and amp draws in some cars are going to make a continuous load that will determine the breaker load rating.
    20. #40
      Jun 2010
      Deployed
      I went ahead and bought a 200 amp breaker. I’m confident it will work…will report back.
