    Thread: Whoa!!!
      Aug 2003
      Prescott Valley, AZ
      Whoa!!!
      I just finished my Hydroboost install and daymnn!!! I had to stop and go back to retrieve my eyeballs. I’ve had disk brakes on my car since I owned it but I knew that I wasn’t utilizing its full potential. Now I’m happier than a pig in shoat. Paul at Hydrotech knows his stuff. To say the least, I am very impressed and Paul said that it only gets better as the system needs some miles to settle in. The install was fairly simple, even though I had to swap master cylinders.
      It's shake and bake!!! and i helped!
      Drewco Homes
      I take it your brakes were not powered to being with? Or is it just that much better then the stock booster?
      Stuart Seitz
      Aug 2003
      Prescott Valley, AZ
      I had a duel bowl 7" booster that sucked even with the vacuum pump.
      Drewco Homes
      Dec 2002
      MusicCity
      detached retinas
      harshman - I hope you atleast rinsed "them earballs" off before you popped them back in
      Welcome to the world of outrageous braking power!
      There IS a difference - Thank you for choosing Hydratech!
      Paul M. Clark
      Founder / Master Engineer
      Hydratech Braking Systems ®
      www.hydratechbraking.com
