    Results 1 to 10 of 10
      Dec 2002
      New York
      Looking for new DFI Setup
      Starting research on changing my current Accel DFI setup on my Accel / Lingenfetlter Superram kit - running the old Gen Vi. Any recommendations would be appreciated - also to mention that I am running a 4l60E tranny - so if there this anything out there that can run both under one platform - that would be good. I believe that Holley makes something for both.
      Running a pre 86 350 block - with a Accel Small cap HEI distributor.
      Sep 2014
      Sun City West, AZ
      I am replacing my Accel Gen 7 system with a Holley. The Holley DFI appears to be a better system. The Holley uses a Wideband oxy and is a self learning system with faster corrections. Also, it is my understanding the Holley has a lot of diagnostics so you can look at previous problems. I'm not sure if it has a tranny control feature. Lingenfelter is installing my new Holley system.
      Kenny Mitchell
      [email protected]
      Kettering, OH
      I'm interested in knowing how you guys plan to handle the wiring harness changeover/conversion. As Accel discontinued all support for their DFI systems, I feel I need to have a plan for converting my Gen7 to another ecm, but my wiring is completely integrated into the car so I don't want to swap the harness.
      Sep 2014
      Sun City West, AZ
      I would assume that the wiring harness pinouts are different for each system. I guess you could review the schematics of each system to see if the harnesses are compatible or rearrange the pinouts accordingly if the connectors are compatible. Unfortunately, my new Holley system is back in Michigan at Lingenfelter and I have my old DFI system here at home so I can't compare.
      Kenny Mitchell
      [email protected]
      Kettering, OH
      Quote Originally Posted by nokones View Post
      Yes, that's what I figured because I cut my Gen7 harness, took out all the unused wires, pulled them to the length needed and reassembled the connector at the ecm: http://1967firebird.atwebpages.com/engine3.php The connector used standard Delphi/Packard pins. So my real question would be, does the Holley unit come with a detailed pin out and does the connector use some type of standard pin? The only problem I had with the Gen7 was that the dualsync distributor used wires of the same color for multiple inputs, making it hard to keep them straight.
      I am also wondering if one could start with the same VE, AF and Timing maps, interpolating if necessary to transpose them to the Holley maps.
      Dec 2008
      Connecticut
      Quote Originally Posted by Hammered View Post
      So my real question would be, does the Holley unit come with a detailed pin out...
      http://documents.holley.com/techlibr...10555rev17.pdf (Holley EFI Wiring Manual - See Section 13, Wiring Appendix)
      ...and does the connector use some type of standard pin?
      http://forums.holley.com/showthread....als-Holley-EFI (ECU Connectors & Terminals - Holley EFI)
      I'm also wondering if one could start with the same VE, AF and Timing maps, interpolating if necessary to transpose them to the Holley maps.
      Yes, Holley EFI also uses Speed Density two dimensional RPM & kPa tables. VE Based is one of the Load Sensing strategies in Engine Parameters.
      http://documents.holley.com/techlibr...r10632rev5.pdf (V2+ Software/Firmware Overview - See Page 6)
      May God's Grace Bless You
      '78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, 4" lift, 35" tires
      Kettering, OH
      Quote Originally Posted by Danny Cabral View Post
      Thank you! This makes a swap look a lot more doable. I found this link that shows how to adapt the Accel Dual Sync distributor to the Holley: http://www.chevytalk.org/fusionbb/sh...hp?tid/266281/
      Dec 2002
      New York
      Thanks for all the great info. I would probably just do a fully wiring harness swap - just to eliminate any potential issues.
      Nov 2012
      ocala fl
      HOLLY HP controls the transmission. Their wiring harness is easy to use. They make wiring harness for the trans and fly by wire. You have to load it in to the unit with a lap top. It also controls boost and a lot of different things. The Dominator EFI controls more and is more for the serious racer. My only gripe with the wiring is the leads under the hood are too short. The water temp is almost 16' too short if you want to keep the big wiring harness "hid" at the back of the motor.
      Quote Originally Posted by chpr1972 View Post
      Holley HP does not control transmission.
      Tom
