      Apr 2007
      SEBRING, FL
      1974 Turbo Pinto (PRICE LOWERED)
      REDUCED
      Update: 09/18/2015 seems turbo blew a seal, won't boost. So turbo will need a rebuild or replacement. Engine runs great, still drives just down on power as you would imagine. reduced to $5800.00 for quick sale, need cash for medical purposes.
      Going to throw this out there. I know its different from the usual Pro-touring cars on here but it could be a really nice car. This is a running driving project that due to injuries from a car accident I'm just not going to be able to finish. It would be a long time before I could finish it and I'd rather just sell it than have it sit. It was going to be a budget Pro-touring car.
      Engine and Turbo:1974 Ford Pinto trunk model. 2.3L turbo swap. Engine completely gone through, new bearings, seals, gaskets, water pump, high volume oil pump, new cam bearings in head, stock forged pistons. Tubular turbo manifold, Garret T3/T4 turbo rebuilt, 2 1/2 down pipe and exhaust all the way back. Converted to external wastegate with manual boost controller, and BOV. LA3 computer with SVO vane air meter on draw through. A/C and power steering deleted, but have brackets for both. Summit Racing Aluminum radiator and electric fan. FMIC. All new belts, hoses, etc. MSD coil and fuel pump.
      Trans: 5speed manual trans, new flywheel, clutch, pressure plate, throw out and pilot bearings. converted to hydraulic clutch with Wilwood master cylinder mounted under the dash, CNC slave cylinder on a custom bracket, with braided stainless steel line. New seals. Ford Racing T5 yoke on shortened 97 Cobra driveshaft with new u-joints.
      Chassis: Out back is a 97 Cobra disc brake rear end with what I believe are 4:10 gears brand new brakes. Mounted on stock leaf springs. Up front are Wilwood Pro-Spindles with brand new steel hubs, ARP 3" wheel studs, Baer billet wheel spacers (not adapters), 13" Disc brakes with dual piston Cobra Calipers, new brake hoses, and all new brake lines. Manual brakes with Wilwood proportioning valve, works great. New tubular upper and lower control arms, new KYB monotube shocks all around. New radius rod bushings. Used HP mesh wheels 18x8 up front with 255/40/18's and 18x9 rear with 285/35/18's. New manual steering rack, with new tie rod ends, and billet borgeson joint. Manual rack turns the 255 tires easily even when sitting, takes very little effort. Even the parking brakes work.
      Interior: Tiburon manual black bucket seats, plain black vinyl door panels, new black cut pile carpet, extra jute padding with heat insulation under carpet. 4 point roll bar, new 4 point street harnesses. Needs rear seat redone or deleted. 97 Mustang Cobra gauges that work. Completely rewired front to rear with 21 circuit kit, many extra unused circuits. All lights work. Rebuilt steering column. Custom fiberglass dash. NO A/C or Heater at this point.
      Other: Fuel lines refurbished, fuel tank was cleaned repaired, resealed inside and painted outside. Looks brand new. Converted to small bumpers (big ugly bumpers are gone). Rolled rear wheel wells, front fender openings were moved upward appx 3" and flared more to make room for the 18" wheels and tires, now there is no issue with scrubbing. All rust has been cut out and welded in new panels. custom power bulge style hood.
      What is needs:
      Car runs and drives although I would trailer it until it is broken in and tuned.
      What the car really needs is the interior to be finished and paint and body work, front and rear valances. Only thing currently not working is the wipers, not sure what it is, they never really worked before but I have an extra wiper motor and the wiring and switch are new, I just can't get under the dash at the moment.
      This would be an easy car to finish for a father and son and you will have a really unique car when finished. You can drive it as it is or finish it.
      I've spent a ton of money and time on this car and have receipts. $7000 obo. I am negotiable on price but I will not give it away, so no lowballers. Located in Sebring, FL. Phone 863-451-2251 if you have any questions. Email is better to reach me during normal work hours, so PM with your email if interested and I will get back to you. Have more pics that I can send.
      Thanks, Travis
      Video of it running: https://youtu.be/vtNxCdmFlV4
      Travis L
      Apr 2004
      Cedar Rapids, IA
      I like different and that is awesome!
      Apr 2007
      SEBRING, FL
      Thanks man! Hate to sale it but that's life...I'll get something else later.
      Travis L
      Feb 2015
      I have honestly considered doing a pinto style pro touring myself. My father was obsessed with them, but have to admit... they were very easy to work on! Totally different, but it looks sharp!
      Apr 2007
      SEBRING, FL
      Quote Originally Posted by Cornbreadx View Post
      Thanks man! Here's you a great one to start with...
      Travis L
      May 2012
      Kansas City, Missouri
      Wow this really brought back some memories. My first car was a pinto. My next door neighbor worked at Ford and built this. It had a 351 windsor in it . God that car was a blast thanks for the blast from the past good luck with the sale
      Apr 2007
      SEBRING, FL
      Quote Originally Posted by thumper877 View Post
      Thats a clean Pinto! They are fun little cars and you don't seem them very often at all anymore.
      Travis L
      Apr 2007
      SEBRING, FL
      Sold!
      Travis L
    Tags for this Thread
