Results 1 to 20 of 22
Thread: Brake Bleeding Troubles
- Oct 2006
- Stillwater Oklahoma
- 183
I feel like have bled at least two 32 oz bottles thru the system. Via the vacuum and the old press and hold method. Good to know I am not the only one however.
In regards to the check valve, that should only be present on the drum or drum disc master cylinders. What master are you running?
06-12-2016 #2Following.
'65 2+2
347 - RetroTek EFI - 471 fwhp
JBA shorty's, 2.5" tubes, Dr Gas X-pipe
T-5 world class 5 speed, w/ .80 OD
9" with 3.70's & T-loc
4 wheel disc brakes
17" Torq-Thrust D's, 225/45 & 245/45
TCP/Global West suspension
OpenTracker roller spring perches
subframe connectors, Traction Masters, Panhard bar
TCP manual rack & pinion
power windows & power door locks w/ keyless entry
06-13-2016 #3
