    Results 1 to 20 of 32
      Jan 2014
      Austin, TX
      SOS........CPP disc conversion kicking my butt
      Ive spent the last 7 months rebuilding a 1960 F100 for the family of a buddy who unfortunately died in a helicopter crash a few years back. The truck is 90% complete but the brakes are kicking my butt.
      I used the CPP front and rear disc conversion kit with the power master and proportioning valve. All brake lines are new and the flex lines are braided stainless. The problem, as it sits, is that while there is SOME braking force, the pedal is complete mush.
      Per CPPs directions and technical support, I've:
      Bench bled the master, ensuring its placed level, in a vice, and the piston is depressed slowly and repeatedly until there is absolutely no bubbles present.
      Adjusted rear integrated parking brake to within the CPP spec of 1/8-1/16 inch movement of the lever arm.
      Installed the bench bled master and bled the entire system using a Motive power bleeder. In this process, the rear calipers were removed from their mounting brackets and positioned to ensure that the bleeder screw at each caliper was at the highest point during bleeding. After pushing over a gallon of fluid through the system, I am confident there is no air remaining in the system.
      Currently, after you bleed the system, the pedal is hard and firm. As soon as you fire the truck up, and the vacuum booster fills, the pedal becomes mush. When driving, there is enough "bite" to safely drive around the neighborhood at 25-30 mph, but the pedal is mush for the top 2/3 of the pedal travel, and from a 30 mph roll, you can't lock the brakes up at all.
      What confuses me is that I have almost the exact same kit on my '72 Suburban (minus the integrated parking brake on the rear calipers), and have never had any issues. Driving the two trucks back to back is a night and day difference.
      Being at a loss, I disconnected the master from the proportioning valve and plugged both outlets. I then checked the pedal firmness just to verify there wasn't any internal problem with the master cylinder, which there wasn't.
      So at this point, I am officially, 100% out of ideas, and 100% frustrated. Any assistance would be greatly appreciated as Im doing my best not to turn sour on this project in the 11th hour.
      Thanks guys!
      May 2014
      Stanislaus County Ca.
      I'm just now chasing a soft pedal with the CPP cadillac style rear brake calipers,
      I'm sure this is where my problem is, since My wilwood master,proportioning valve and 6 piston front calipers were fine before. I've done the E-brake adjustment multiple times, removed the calipers pointed the bleed valve straight up to remove any air..........the only thing I haven't done is to plug the rear lines to isolate them and see if I have a pedal.
      I'm thinking it was a mistake to put this new rear on with these brakes and not just buy some wilwoods.
      Jan 2014
      Austin, TX
      yea....Im with you....my Corvette is going full Wilwood (if I ever get to it), but this being a mostly stock rebuild didn't really justify anything other than a basic disc upgrade. The thing I don't quite get is, even if the rear calipers with the E-brake are SLIGHTLY out of adjustment, would that really affect pedal feel this much? I mean my pedal is a straight up limp noodle. And after re-addressing the e-brake adjustment multiple times, the "bite" has gotten better, but the pedal still feels like crap.
      I attempted plugging the rear line to isolate it today, but thats harder than it sounds given the way they have the proportioning valve and hard lines set up....I tried for about 30 min. but couldn't actually get the rear out of the master with the front still connected without significantly bending the front hard line. Let me know if you have any success with it.
      Like I said, I used the rear calipers minus the e-brake on my suburban and had zero issues.
      Sep 2012
      San Diego
      i ran into this with a cpp kit. did all the above with no improvement. finally i got some brake pressure gauges and would only get about 700psi. once i told cpp that, they asked what the engine vacuum was (14in/hg). they said thats not enough. it needs to be at least 19 in/hg at idle for their booster to work. we swichted to hydraboost and all of a sudden the brakes worked great.
      so check your engine vacuum and if its not over 19"s then you have found your problem.
      71 maverick.
      71 comet in build process.
      i work at Current Auto Performance www.currentautoperformance.com. i also build the differentials for San Diego Gear and Axle.
      Jan 2014
      Austin, TX
      thanks for the tip....Ill look into it tomorrow
      Lawrenceburg, TN
      Quote Originally Posted by FLYNAVY53 View Post
      yes..there is no telling what the pressure was before...buy now its roughly a third less
      unscrew the rear bleeders .....completely remove them.. make sure they are cleared and working and while there out use a vacuum bleeder...or pump the peddle and see if you're getting fluid thru the bleeder holes
      Mar 2012
      Escondido CA
      Seems like a vacuum or booster issue, could the new booster be bad?
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
      Jan 2014
      Austin, TX
      thats what Im leaning towards....going to put a vacuum gauge on it today and verify that Ive got enough vacuum at idle and go from there
      Jan 2014
      Rhode Island
      I just had the same situation hard when bleeding then would drop and go wet noodle when running on booster. I have a 69 camaro with the Cadillac conversion calipers. I had done everything exactly as you described , ended up using a longer rod between the booster/master. I think when it was running under vac. On the booster it was just placing the mc piston in the wrong place on its stroke . So maybe try a longer rod or even adj. your pedal at the column.? Good luck.
      1969 camaro pro-touring.
      link to my album:http://photobucket.com/albums/xx160/...ro Restoration
      Steve
      Oregon
      In my experience, a bad booster or low vacuum would typically result in a high, hard pedal with a low brake-torque situation, not a low and mushy one. So while it certainly doesn't hurt to check the booster and vacuum levels, I don't think that's your problem. Low vacuum levels don't suddenly somehow cause the booster not to work, it just proportionally reduces the amount of gain or boost that it provides. While boosters will work very well at 18" Hg or more, they work reasonably well all the way down to 14" Hg in my experience and marginally well all the way down to 11-12" Hg. That said, booster size and configuration tends to be just as important, so an undersized booster (i.e. dual-7", single-9", etc) paired with low vacuum is certainly going to be less than ideal.
      You want to make sure the booster output rod and MC piston has about .015" to .020" clearance. Too much and your pedal travel can be excessive. Too little and it may not allow the pistons in the MC to fully return to their home position, possibly maintaining residual pressure in the system.
      Which CPP brake kits are you running specifically? Calipers and caliper piston areas? What bore size master cylinder? When you tested the MC by plugging both outlet ports, did it hydraulically lock after minimal pedal travel and not sink over time? When you reconnected the hard lines, did you do it one circuit at a time or both at the same time? That would at least tell you which end your issue is located, allowing you to focus your energies there.
      Tobin
      KORE3
      It's what I does.
      Jun 2006
      Katy,TX
      If they are the Caddy, 79-81 TA rear disc calipers that ratchet the ratchet is what keeps the piston and pads near the disc. They need to be ratcheted to where they grab the disc and then put on the bracket for the E brake. The E brake needs to be used almost every tome you stop to keep the pad close to the rotor as it wears. They are bad about locking up also and not ratcheting close enough.
      1965 GTO project car
      2004 Pulse Red GTO
      Jan 2014
      Austin, TX
      How did you determine the rod from the booster to the master was too short and how did you determine what length to use? Also, how did you remove the rod from the booster....Ill try to get a pic posted of mine here in the morning. Thanks for the help!
      Jan 2014
      Austin, TX
      Quote Originally Posted by stevenp0827 View Post
      Jan 2014
      Austin, TX
      Quote Originally Posted by Apogee View Post
      Tobin
      KORE3
      Tobin, the CPP kit Im using is 5760CBK5.5 front and CP2505-50-5512 rear. Unfortunately they don't list bore and piston size on the web site. They are the very base model, single piston calipers.
      When I tested the master by plugging both ports, it did hydraulically lock with a slight amount of pedal travel with no sink over time. I did not check each circuit individually, which I suppose should be my next step tomorrow. Unfortunately I was unable to get out of my neighborhood today to pick up a vacuum gauge, or more brake fluid because the hotel across the street burnt to the ground this morning and they just opened the street up recently...what a waste of a free day off work......
      I appreciate all the help!
      Jan 2014
      Austin, TX
      Quote Originally Posted by Skip Fix View Post
      Yup! After multiple hours, they're adjusted properly....drivers side is just under 1/8 inch of travel and the passenger side is just over 1/16 inch of travel. both sides have equal drag when you spin the wheels. Pedal still goes limp as soon as the truck is running.
      Apr 2007
      Minneapolis, MN
      I ran into the same issue in my brothers c10. Does your truck have the parking brakes hooked up? His were not hooked up. So as a test I removed the big springs between the parking brake lever and caliper and then very slightly applied the parking brakes by pushing on the levers by hand then drove the truck. The pedal was great after that. Installed parking brake parts and got them adjusted. The brakes are working well now. It did 1,200mi of power tour this year and the pedal was spot on. The parking brake has to be used frequently to keep the adjustment tight.
      Oregon
      Please measure the pin to pin distance on the front calipers. If it is 5.47" [139mm], then you have the GM D154 metric calipers. These calipers use a low-drag square o-ring seal designed to retract the piston in the caliper further than other conventional caliper designs, which means that they tended to work best with quick take-up master cylinders designed to account for the greater volume required to take up the slack in the system prior to actuation.
      This design feature plus the inherently finicky rear Caddy calipers could very well be the bulk of your pedal feel problems.
      Tobin
      KORE3
      It's what I does.
      Jun 2006
      Katy,TX
      The Caddy/TA rear calipers are the same spread as a D154 if you need to do a cheap trial if it is those calipers. Oreiley or Autozone "plain" metric front calipers form a late 70s early 80s Malibu. Most have a 2.5" piston. I have them in place to the ratchets n the 79 Camaro race car
      2004 Pulse Red GTO
      Jan 2014
      Austin, TX
      Update.....
      Decided to start over so I re-bench bled the master cylinder and reinstalled it. Just for giggles, I tested the pedal feel with the bleeding apparatus still installed and the pedal felt as expected. I then plugged both ports and tested the pedal....there was a very minute amount of slop in the linkage followed by about 3/4 - 1 inch of pedal movement before it locked up and would not depress further.
      I then left the rear port plugged and attached the front to the proportioning valve. Pedal felt great with the truck off. With the truck running, and vacuum going to the booster, the pedal once again felt like a wet noodle. Turn the truck off, bleed off the pressure in the booster, and the pedal returns to feeling solid.
      I then connected the rear port and plugged the front. Same story. Solid feel with no booster, felt like crap with the truck on and the vacuum line attached.
      At idle, the truck pulls 19-20 in. of vacuum.
      Any thoughts on what Im missing here?
      Jun 2006
      Katy,TX
      Sounds like a bad booster. Make the jump to full manual??
      2004 Pulse Red GTO
