    Results 1 to 1 of 1
      Boise, ID
      Comp Cams Rocker arms 1.6 Ratio
      Building an engine- changed mind on heads. 1.6 Rocker arms for sale. New, never installed. Best price seen around $155
      $100 plus shipping.
      Just updated profile-Am now in Boise, ID
      Description from Summit:
      Finally, you can get high performance without a high price with COMP Cams High Energy die-cast aluminum rocker arms. COMP Cams, a leader in valvetrain technology, has developed these High Energy rockers to provide a superior strength to weight ratio to withstand the hardships of your street performance and mild race engines, while adding valve lift. These die-cast aluminum, larger-than-stock rocker bodies are designed to be stiffer and more durable. They feature needle-bearing fulcrums and roller tips to reduce friction and lower oil temperatures for even more horsepower potential. Maybe you're on a budget, or maybe you just appreciate getting the most for your coin; make an affordable choice without sacrificing performance--get COMP Cams High Energy die cast aluminum rocker arms.
