    Page 2 of 2 FirstFirst 1 2
    Results 21 to 39 of 39
    1. #21
      Aug 2012
      Peoria, AZ
      The end of the crankshaft is different between the 1 piece and 2 piece RMS, this the way the flywheel is designed to attach to the crank is different. I believe from the face of whichever flywheel you use back is the same, so once you install the flywheel you can use everything else you already have from the donor car. No need to change anything on the trans itself.
      This is assuming you swap in the hydraulic clutch setup that is on the donor car of course. Not sure you can use your manual clutch linkage setup because the LT1 T56 uses the unusual push type clutch fork assembly. Swapping in the F-body clutch master should be a pretty easy swap as well.
      Lance
    2. #22
      Feb 2013
      Nice! I had a 95 Trans Am a few years ago. I got hit, totaled it out, bought it back from the insurance company, and parted it out for a good amount more than what I paid to get it back. Definitely a good plan on putting the T56 behind the 383, it'll be fun!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    3. #23
      Quote Originally Posted by minendrews68 View Post
      It is a early 2 piece rear main seal. (of course). Is the input shaft readily available? Is it a pain to put in? Is it cheaper than the flywheel?
      Out of curiosity, what is the difference in the two flywheels? (the one piece rms or the two piece rms?) I know questions, questions, questions...
      Think it's flange and bolt circle diameter. 2 pcs is bigger since it doesn't need to o through a 1 pc seal
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    4. #24
      Jonesboro, Arkansas
      Does anyone know if there is a place for a gear driven speedometer on the T-56? What other electrical components are on this trans?
      Carl Wilson
    5. #25
      Aug 2005
      Hamilton, NJ
      No mechanical speedo. Although i think someone, maybe jags that run, make a new tail housing with a speedo provision.
      Electrical: reverse lockout solenoid, vss, reverse light switch, skip shift
      Scott from NJ.
      Vent Windows Forever! ...
    6. #26
      Jonesboro, Arkansas
      Do you know of any information source that tells how to hook these things up?
      Carl
      Carl Wilson
    7. #27
      Dec 2010
      Fredericksburg, VA.
      Since Carl has a 2 piece rear main seal, the need to change the flywheel would be due entirely to the different style clutch of the LT1 and like you said he would not be able to use his existing manual clutch linkage. So with the LT1 T56 he would have the expense of a special 2 piece rms flywheel for the LT clutch plus most likely a new clutch it's self and all the hydraulics to operate it. Some of the non-wear parts could be salvaged from the donor car but there would still be a fair amount of fabrication involved. On the other hand, with an LS T56 he can reuse all his current flywheel, clutch and linkage with no modification by using a simple adapter plate. I suspect the transmission can be converted to LS for a whole lot less money than the sbc flywheel/clutch converted to LT.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    8. #28
      Aug 2012
      Peoria, AZ
      Yeah, that might be an idea. I'm not sure what all is involved with converting it to an LS style but I know a couple of people that have done it. Worth checking into for sure.
      Lance
    9. #29
      Jonesboro, Arkansas
      Hey guys, I appreciate all your help so far. I'm like Steve, I'm going the LS route. He's done it successfully and seems to know what he's doing. So I'll follow his advice on this one.
      Carl Wilson
    10. #30
      Jonesboro, Arkansas
      This car has a LT-1 engine in it, my son wants to put a LS engine in it, I say we fix up the LT since we have it already. Take in mind that he's in college, working, but once he starts back to school his paychecks are going to be cut. I have successfully lost this car. I was going to sell the car after I got the six speed out to put in my '68 Camaro. Now my son wants to fix it up for himself. At the risk of losing my six speed I'm thinking about putting a automatic in it. He's wanting a six speed/LS-1. Now I'mg losing my whole car lol! I'm thinking we need to fix up the LT engine and call it a day. What do you guys think? I guess we could sell the LT engine to help fund the LS just don't know.
      Carl Wilson
    11. #31
      Dec 2010
      Fredericksburg, VA.
      Carl,
      Sounds like you have a conundrum on your hands. Did I read earlier that your son got the car running? If so, I would just drive it as is until he finishes school. Then you can decide what to do with it at that time. Meanwhile you could start looking for a salvage yard LS T56 or maybe a new T56 Magnum. Something to consider though, a typical used T56 will likely need some repairs to get it in top shape not to mention all the upgrades that are available for these transmissions. By the time you add up the used T56 purchase price and repairs you might be money ahead to just buy a new T56 Magnum transmission or even a complete T56 installation package.
      http://www.hurst-drivelines.com/?page_id=4420&id=9
      Just something to think about.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
    12. #32
      Jonesboro, Arkansas
      Carl,
      Yeah, I do. He's wanting a 6 speed as well, I told him last night there was no reason for me to take this transmission out and him find another one, the only thing now is I've lost my complete donor car!! lol.
      What do you think about leaving the LT engine in for now and just get it running right and fix the rest of it up? It will start and run, but then dies about 30 seconds later. Although, it will start right back up and do the same thing again. The guy we bought it from said they replaced the head gaskets and when they put the intake back on, the rear intake seal "pushed" out and they just left it alone at that point. I'm guessing we'll pull the motor and trans, get it fixed right and clean things up and start from there. I'm for leaving the LT engine in and calling it a day... I've lost my donor, but hey what the heck, Andrew likes hanging with the ol' man working on cars, so I guess I'm good with it........
      Carl Wilson
    13. #33
      Portland, OR
      Not a bad suggestion. I did it the other way piece by piece putting an LT1 T56 behind a 408 SBC. Not hard, just took time to get educated on the parts to do it right. I used the stock bell housing and converted to F-Body hydraulics. Your parts list would consist of a pricey flywheel (2pc, external balance?), clutch, driveline work, crossmember, bracket for clutch master, clutch master, clutch slave (plus mods to clutch pedal and master pushrod), clutch line, wiring, and in my case exhaust (h pipe hit the tailshaft since the T56 is longer).
      Completely worth it though.
      Can't beat that.
      Ben C. - Sometimes Complete > Perfection - I just want to drive my car...
      1969 Nova 408/T56 | 2003 XJ8 Sport LS2/T56
    14. #34
      Jonesboro, Arkansas
      Well, I may have found another 6 speed for my Camaro, I'll know tomorrow. Looks like Andrew might be able to keep his Tram Am 6 speed after all.
      Carl Wilson
    15. #35
      Jonesboro, Arkansas
      OK, surely not another problem....... I got my adapter plate in today (McLeod) from Summit. This is to bolt the LT trans to my existing bell housing. I wasn't sure how it went so I called McLeod. He informed me that I now need the intermediate housing off of a LS trans to go with everything I've had to buy so far. Something about the LT trans has the "snout" that the throw out bearing rides on, and the adapter plate has one also. Am I going to have to buy this piece off a LS trans too?
      If the problem with the LT trans and the collar that's built into it hitting the adapter plate, couldn't I just cut the collar down (below the face of the housing where the adapter plate bolts on)? Then, I could bolt the adapter plate onto the trans since it has a collar that comes with it. Just a thought...
      Last edited by minendrews68; 08-15-2015 at 06:15 AM. Reason: added another question
      Carl Wilson
    16. #36
      Jonesboro, Arkansas
      Some things not to buy. I called Summit and asked about the Hooker transmission mount 12626 HKR. They told me it was for the T-56 transmission into a 67-69 Camaro. I ordered it and got it installed yesterday. Today, my son and I got the bell housing and everything back in and as I was looking at the setup through the big hole in the floor board something didn't look right. I measured the distance from the face of the adapter plate on the bell housing to the mid point of where the transmission mount bolts to the rear cross member. That distance was 18.50". I then measured the distance from the front face of the trans to the center of the rear trans mount, 21.5". I called Hooker and after a 36 minute wait I was told that that cross member would not work with my situation. Now, I'm in a demise as to, should I weld a flat piece of steel onto the back of this cross member to move the mounting position back 3", or try to find another one. I think Summit will take this one back, just a hassle trying to find another one..
      Carl
      Carl Wilson
    17. #37
      Dec 2010
      Fredericksburg, VA.
      As I recall I used the Summit brand T56 cross member and it was a similar issue. I had to modify the mount to work but that is just part of playing this hot rod game.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
    18. #38
      Jonesboro, Arkansas
      It is, I guess things like this just keeps it interesting..
      Carl Wilson
    19. #39
      Jonesboro, Arkansas
      I went to install the trans Saturday afternoon. I measured the distance from the face of the transmission to the end of the LS input shaft, it is 6.5". I then measured the distance from the pilot bushing (http://www.summitracing.com/search?S...d=aaf-all26114) to the face of the adapter plate (http://www.summitracing.com/search?S...word=mcl-8-207) it was 5.13". This gives me about .38 of engagement of the input shaft to the pilot bearing. I don't see this as being enough. You guys have any suggestions?
      Carl
      Carl Wilson
