      Houston, TX
      67 Pontiac Firebird 400
      Car is a Firebird 400 with turbo 400 from the factory. Deluxe interior/rear antenna/center console option. I had a PHS doc somewhere, not sure where it's at after the move to Texas.
      Engine/trans: 5.3/4l60e swap from a 2001 Silverado. Was told it had 85k miles on it. Cylinders still have cross hatching patterns. Transmission has a Corvette servo upgrade. Mast oil pan/DSE LS swap motor mounts/Dynatech headers. PSI wiring harness.
      Fuel: tanks inc with internal fuel pump. Corvette fuel filter/regulator.
      Body: quarters/trunk pan had been replaced. Original doors/DS fender. Metal/body work done by me, final paint by a body shop in Portland, OR.
      Chassis: stock subframe. Hotchkis subframe connectors. Recently added a DSE roll bar with removable harness bar.
      Suspensions: SPC upper/lower control arms/Speedtech AFX spindles. Hotchkis 2" drop springs front/1.5" leaf springs rear. ridetech single adjustable shocks all around.
      Brakes: Wilwood Aero6 6-piston calipers front with DBA 4000 13.25 rotors, LS1 rear brake with working parking brake.
      Wheels/tires: Formula 43 S6 wheels (18x8.5 front/18x9 rear) with Nitto NT05 tires.
      Misc: VHX guages, new AAW wiring harness, LED tail lights. Every nuts/bolts had been replaced. Vintage Air working nice and cold.
      Looking to get $35k firm.
      You can see the thread on the car in my signature. Car has clear Tx title in my name, and located in Houston Tx.
      Tu Ho
      Firebird V2-LS swap
      Bump for a clean looking bird
      Houston, TX
      Bump
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      btt
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Bump.
      Will consider reasonable offers.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      ttt
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      ttt
      Tu Ho
      Firebird V2-LS swap
      May 2011
      Philadelphia PA
      Really nice car, I can tell you use this car. Awsome
