    Results 1 to 11 of 11
      Apr 2011
      Missouri
      Is a Hand e-Brake helpful for Auto-Crossing?
      When designed a cardboard template for our center console, if we're going to have any storage compartment at all, I don't see room to include an hand e-brake like the one from Lokar. I'm leaning to just reusing the OEM foot e-brake instead, but my son (co-builder/owner) says we need it.
      1971 Olds Cutlass Supreme
      T-56 Magnum required bigger trans and drive shaft tunnel.
      We plan to mostly just go to cruises but plan to autocross several times per year. Looking at a lot of PT cars here (tommycomfort's 66 Chevelle and analyte's 66 Chevelle), I didn't see a center floor mounted hand e-brake. On analytes I noticed the OEM foot e-brake in one of his pictures.
      So it a floor hand e-brake needed or used for auto-crossing?
      GaryB
      Current Project: 1971 Oldsmobile Cutlass Supreme
      Current plans include: Full RideTech Coil-Overs, Olds 455, Holley Terminator EFI, Edelbrock heads, Tremec T56 Magnum, custom dash, custom console, Dakota Digitial VXH-1017 gauge cluster, manual brakes, 3.42 gears, etc...
      Mar 2014
      Burlington, KY
      For fast autocross times, you normally don't want to be drifting.
      1969 El Camino
      Apr 2011
      Missouri
      Thanks I will relay that to my son and an OEM foot ebrake will be used.
      GaryB
      Dec 2010
      Fredericksburg, VA.
      You might consider an E-Stopp system. It can also act as a theft deterrent system.
      http://www.estopp.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Apr 2012
      Woodstock, IL
      Some guys use it, and by some I mean 1%. I haven't found it to be helpful. It's a little harder to get A-bodies to swing around quick anyway. EStopp systems are great and we've used them many times, especially when there is no room for a pedal Ebrake- such as when you have kick panel speakers. Otherwise I like the foot brake.
      -Dale
      SchwartzPerformance
      Sep 2014
      Sun City West, AZ
      It is only needed when you are going for "Style" points. If you want to be fast, "NO".
      Kenny Mitchell
      [email protected]
      3rd on the E-Stopp. Recommended.
      ​John Parsons
      Aug 2012
      Peoria, AZ
      Only time I could the benefit of one is at the starting line of a Pro-Solo on a sloped surface...
      Lance
      In 20+ Years of A/Xing, I think I have used an E-Brake once!
      Hildebran, NC
      Usefull for autocross, probably not.
      my next car will have one though!! I love to slide around.....
      http://www.asdmotorsports.com/produc...-back-e-brake/
      Sliding around
      Mar 2014
      Burlington, KY
      I hear Wilwood is installing a hydraulic e-brake so they can take their Mustang drifting
      1969 El Camino
