      Feb 2014
      Boise , Idaho
      Oversize fuel pump or ?
      So I am doing my research to swap the 327 out of my 64 El Camino to a 5.3 liter Vortec and in my searches I am seeing that the Walbro fuel pumps are basically rated by HP . While I can't really see the motor making more than the 450 HP the smallest of their pumps will support the price to move up to a pump that will support up to 630 HP is only 20 or so dollars . Would it be OK to run the larger pump just so that I could upgrade to another motor or some sort of boost later on or will the larger pump cause problems now ?
      Feb 2015
      The biggest thing that always killed my oversized pumps was dead-heading them with no return -- they would just heat up and die --
      I bought an Aeromotive 1000 for my little 400HP project, but I got a huge regulator (alcohol rated) that returns excess fuel back to the tank and I made sure that I ran the same size lines and filters (#8 or 1/2") for the supply and return -- no problems in 3 years
      Feb 2014
      Boise , Idaho
      I would be running a Corvette style filter which has a return built into it so would that work ?
      Newbury Park, CA
      There is nothing but drawback when running too large of a pump. Excessive heat generation, all of which gets dumped into the fuel load, can lead to a host of troubles.
      A simple Walbro 190lph pump will suit the fuel delivery requirement if the engine is stock or mildly modified. Controlling the fuel and keeping it around the pump during cornering, braking, etc. at low fuel levels is a different matter.
      Jan 2013
      Cypress, California
      Yes. That is what I am running with my Walbro 400lph pump. The 255lph pump will work just fine. Maybe even the smaller one. However if you are going to do upgrades for more power keep that in mind when selecting a fuel pump.
