      Feb 2014
      Boise , Idaho
      Fuel line question
      I am looking at the Tanks Inc. fuel tank for my 64 El Camino and after looking at the options I was wondering if the fuel line kit they offer for LS motors is worth the 235 bucks they are asking ? Is there a less expensive way to piece this together or does this seem like a good value at 235 bucks ?
      http://www.tanksinc.com/index.cfm/pa...rod/prd453.htm
      This fuel line kit includes 25 feet of line and all the fittings that you need for your LS engine swap using our fuel pumps. This kit is designed for LS engines that have a single fuel inlet fitting.
      • # LS9904 Fuel Filter/Fuel Regulator
      • # 640940 Russell 3/8" Male Quick Disconnect to -6AN Male Fitting (Fuel Feed from Regulator to Engine Fitting)
      • # 640853 (x2) Russell 3/8" Female Quick Disconnect to -6AN Male Fitting (Fuel Regulator Feed from Pump and Fuel Rail Fitting)
      • # 640863 Russell 5/16" Female Quick Disconnect to -6AN Male Fitting (Fuel Regulator Return Line Fitting)
      • # 660443 (x2) Russell 1/4" NPT to -6AN Adapter fitting (fuel pump Pickup and Return Line Fittings)
      • # 624013 (x6) Russell Straight -6AN Straight Twist-Lok Fittings
      • # 634173 (25 feet) Russell -6AN Black Twist-Lok Fuel Hose
      Pensacola, FL
      My buddy just got that kit for his C10. We probably wont get it installed for a couple weeks. When I do the first gens, I buy factory bent stainless fuel line & have a line shop make me braided hoses and install AN fitting at each end of the factory line. I just like having the hard lines. But it costs more than the above kit.
