    Thread: Ls2 question
      Nov 2010
      Ls2 question
      Can someone show me the configuration of the hoses on the back of their ls2? There is 2 nipples coming out of the intake and a nipple coming out of the back of the drivers side valve cover. Thanks for the help!
      Pensacola, FL
      The port on the driver side rear valve cover gets capped. The valley cover port goes to the intake port thats located just above the valley port. The passenger side valve cover goes to the intake tube if you have a DBW TB. I plan to drill & tap the intake tube for an elbow. On a cable TB you can run it right to the port on the top of the TB.
      Nov 2010
      Ls2 question
      Awesome thanks! What goes to the port at the back of the intake?
      Pensacola, FL
      All the LS2s I've used have it capped from factory. Not sure if the TBSS or truck setup is different, as I believe the port on the valley is capped off on those.
