    Results 1 to 1 of 1
      livermore ca
      65 chevelle reverse lights
      Need some help, I have installed a AAW wiring harness throughout the car (65 chevelle) all my head lights,dash lights and tail lights work but I'm having trouble with the reverse lights... I have the 2 wire (pink an green) for the back up switch hooked up to the shifter(B&M), pink (12 volt ign) & green (back up light switch). The pink is hooked up to the switch that says ON and the green is hooked up to the prong that says COM. Is that correct? There is only 2 prongs on the switch not for like the original, so are those 2 prongs just for the neutral safty? Do I need a different style witch? I'm kinda lost on what to do now I have tried everything I could think of, only thing I think could be wrong is not getting good enought ground on the back light housing since they are not hooked up to the bumper yet. But I have been holding the mounting screws to the truck pan to bare metal to ground them for the time being. Any info would be awesome as its the last part before buttoning up the rear half of the car an wiring... thanks
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
