Thread: Best Diff for 600-700hp?
10-22-2005 #1
Well, as the car grows more and more out of control, the hp of the engine does too. Im shooting for about 650 at the flywheel, and thats hopefully enough to get me into the 10's. My question is, which differential should I go for? The car is going to be 94% street driven, so I don't really want a Locker, and the next best thing would be a Tru-Trac.
The question on my mind is... if I spring for a D-1SC instead of a P-1SC blower, the engine could put a lot more out than that... so I don't really want a croumpled rear. What do you all recommend?
I've spoken to Currie, Moser, DTS, etc. and they some say that 650hp should be OK, others no...
What about you guys?
Max
10-22-2005 #2it really depends on what you are going to do with the car, if you never plan to put slicks on it, or do high rpm clutch dumps, then you can get away with a less beefy rearend. I probably have 630hp or something like that, at least 600 and am only running a 8.5 ten bolt, with 30 spline posi, moser axles and U.S gears with a rearend girdle cover. I don't plan on much drag racing and think this rearend should last a long time. Its also lighter and cheaper than a lot others, there are guys with spools and 8.5's running 9's
10-22-2005 #3No slicks (well, drag radials
Originally Posted by yody
), no high RPM launches. I will drag race it a bit, but not a lot. Mostly cruising around town. I'm going to be running (probably) a 9" from DTS w/ a nodular strange housing and the likes. DTS uses, amoung others, Strange parts and they are cheaper than the other companies direct. I got a quote in the $2150 area where Moser and Strange wanted $2300-2350. My weak link is going to be my transmission, I would think. I have a local guy who will guarantee (I know that many people here would contest this number) his 700R4 for 700hp for $1200. Can't go wrong with that number (as compared to $4k for a 4L80E).
As for higher hp (than 600-650), I just need it to hold up for a couple dyno pulls if I spring for the D-1SC, because, where the hell am I going to use 800hp on the street
Thanks for the imput Yody.
-Max
10-22-2005 #4hmmm, 700hp 700R4 tranny for 1200 bucks huh? I would run from that deal as fast as i could, never look back. Don't waste your money. Buy a real tranny NOT a 700r4.
10-23-2005 #5
