    Results 1 to 12 of 12
      Tampa, FL
      does any one have a vapor lock solution ?
      My BBC, electric fans, and mechanical fuel pump is showing signs of vapor lock when the engine gets hot. I have a 2" cowl hood but I guess the engine compartment still has too much heat in it. I'm told this is a common issue with BBC in a small engine compartment like a Camaro. I'm hoping someone has a solution.
      Thanks in adavance,
      Max
      68 rag top
      427 ZL1
      Pflugerville, TX
      Mine did as well until I upgraded to an electric pump with a return line to recirculate the fuel and keep it cool.
      Mar 2004
      Mid-Michigan
      Like above^^^^. Can I ask where your fuel lines are routed right now? If they are anywhere within 3 or 4 inches of your headers or collectors heat will be a problem. Routing the lines away from the exhaust is one solution.
      Also, how is your carb mounted to the intake? Just one gasket, otherwise it is directly on the intake? if so a phenolic spacer will go a long way to keeping the float bowls cooler.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Feb 2013
      South Carolina
      If it's really bad, you could install one of these:
      http://www.terrysjag.com/category/XJS-FUEL-COOLER.html
      Newbury Park, CA
      Do you have a carburetor heat shied installed?
      Tampa, FL
      I don't have one installed
      68 rag top
      427 ZL1
      Tampa, FL
      I assume it cools the fuel ?
      68 rag top
      427 ZL1
      Tampa, FL
      68 rag top
      427 ZL1
      Central CA USA
      Get a carb heat shield, and install a fuel filter for an air conditioned car. If you can't find one for a BB Camaro OEM style, look for a 68 Cadillac fuel filter. It goes between the fuel pump and carb, has a small return line back to the tank with a jet in the return line.
      http://www.ebay.com/itm/like/2315416...lpid=82&chn=ps
      Tampa, FL
      Thanks David I'll try that
      68 rag top
      427 ZL1
      Tampa, FL
      Fuel line and mechanical fuel pump is within inches of header
      68 rag top
      427 ZL1
      Mar 2011
      Ca
      if you can't move the fuel line wrap it in heat sheild, as for the pump electric would eliminate a ton of heat soak into the fuel. also a carb spacer will help just stay away from the metal ones.
