    Thread: Fuel Leak.
      Nov 2004
      Eastern Washington
      Fuel Leak.
      I am having an issue with a fuel leak in my 79 TA. If I let it sit and run, I see no issues. However, when I turn off the engine and let it sit, go out several hours later, and there is a pretty big pool of fuel on the ground....under the engine. Do you have any ideas what might be causing this? Has anyone heard of it before? It sounds like it might have something to do with backed up pressure, but I could be wrong.
      Nov 2004
      Eastern Washington
      Turned out it was just a leaking hose from the fuel pump. Guess I didnt look hard enough the first time....if anyone cares.
      Jul 2002
      Mesquite, TX
      Not sure why I didn't see this post yesterday.. but yeah, followups are always good in case others have the same issue and do a search.
