      Aug 2014
      Missouri
      1969 Camaro shell
      I could possibly make this a roller if needed. The chassis, engine, trans, and forgelines are not for sale.
      I found a bone stock z/28 body and although it is a complete different direction from all the manhours already put in this body, I've decided to put it up for sale. The body is straight and rust free.
      Body
      Molded in rear bumper
      Smoothed firewall, full new steel plate not a thin filler plate.*
      New dash new doors new rockers and the quarters were done not too far back. Body shop said whoever did them did a good job.*
      Full new smooth floor sheet metal
      Full made transmission tunnel
      Full new trunk section - flat floor with fuel cell pocket recessed in, battery /storage compartment hand made and lid
      Trunk hinges are in it. Door hinges bolted up also
      Shaved drip rails
      Welded and smoothed rear filler panel seams
      I may have trim, speaker covers, door latches, whatever my buddies doesn't have
      New goodmark 2" Cowl hood
      Good trunk lid
      I believe new front fenders
      Inner wheel wells
      I also believe the front nose piece, vent Cowl, and lower front steel piece by fog lights are also new.*
      Core support
      Front glass
      Taillights
      New in box full trunk section in weld through primer, cut for mini tubs
      New mini tubs
      The other clip I have is that, a full front clip. Rad support, inner and outer fenders, grille, lights, headlights, braces etc.
      The rear end is a 61" flange to flange I believe winters aluminum 9" rear end. Never had a third member bolted to it or oil in it. It's a full floater rear end. I have the coleman aluminum drive flanges for it too.
      The fuel cell is a RCI 19gal aluminum, never had fuel in it. The trunk was sized around this cell.
      Tb is a FAST 102 mm cable driven with TPS. Still in shrink wrap in the FAST plastic briefcase they send them in.
      $12,500 for everything above. I will split the throttle body and 9" rear but don't want to sell anything else first at this time.
      located an hour south of St. Louis, MO. PM or text 5735359955.
      Aug 2014
      Missouri
      I can't upload pictures for some reason from my phone, but will get them on here as soon as I can get to a PC.
      Aug 2014
      Missouri
      Some pictures added.
      Aug 2014
      Missouri
      Bump. Two buyers vanished after a couple weeks of talking to each. If anyone needs additional pictures, I can e-mail them over.
