      Dec 2009
      Las Vegas,Nevada
      DSE fuel pump access panel install
      Has anyone installed a DSE fuel pump access panel kit. If so, did you install it above or below the tuunk pan and did you perimieter weld or plug weld the tap plate to trunk floor.
      Any pictures would be helpful.
      Atlanta, GA
      I did mine before DSE came out with their kit. I did mine above the trunk floor and plug welded a framed out some steel around the top to form the frame. I then cut a piece of aluminum for the removable panel. You can see some pics in my build thread.
      Dave
      1972 Nova
      1967 RS/SS Camaro - current project
