      May 2012
      Kansas City, Missouri
      safety wire or locktite
      Assembling my brakes and was wondering what's the best way to. I have wilwood 2 piece rotors. Car will mainly be street driven but I'm planning on some autocross use when I can. Do I need to safety wire or is locktite ok. Any help or advice would be appreciated thanks
      Dec 2010
      Peoria, AZ
      I believe the instructions recommend using both. Red loctite on the bolts and then follow with safety wire. That's how we assembled the two piece Wilwood rotors on our cars.
      I gave up on traditional safety wire after a friend in the aerospace sector showed me the Safe-T wire tools from Daniels Manufacturing though. Expensive but much faster than traditional safety wire and if it's good enough for holding together a jet engine, it should be good enough for the places I use it on the car like the two piece brake rotors.
      http://www.dmctools.com/Products/safe-t-cable.html
      Tom Pichette
      Pit crew for Valerie Pichette and her 1988 Pontiac TransAm GTA "DragonLady"
      Dec 2010
      Fredericksburg, VA.
      You pretty much have to use safety wire. Locktite is not a substitute for safety wire. Even the high temp red locktite is only good to about 400deg as I recall. Brakes can get much hotter than 400deg even in mild street driving. I like that DMC wire I may have to get me one of those tools.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Beach Park IL
      Thanks for the DMC link!! That is a neat solution.
      Donny
      Nov 2011
      Livermore, CA
      Ditto this that is neat. Although I didn't mind doing mine with traditional safety wire.
      Tory
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
      Jan 2009
      Hermosa Beach, CA
      Safety wire is a PITA and overkill for most situations. IMO : )
      Pete
      1968 Camaro
      2009 Porsche 911 Carrera S
      http://www.cardomain.com/ride/2543199
      Jun 2012
      Loctite should not be used in high heat areas.
      Safety wire is a must. I have seen bolts come out of wilwood hubs that were not safety wired.
      Having someone show you how to do it will make it much easier.
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Jun 2006
      Katy,TX
      I picked up an OLD Wilwood Dynalite drag kit for second gens before they added the safety wire. the Loctite used is strong enough the allen wrench holes are trying to round off. '67 GTO and Chevelles with 4 piston calipers had two piece rotors and no safety wire.
      That said I did both on the newer kit ion my 79 Camaro but my safety wire is not pretty!
      1965 GTO project car
      2004 Pulse Red GTO
