      Dec 2011
      4l80E Transmission controller advice suggestions
      I recently purchased a 4L80E transmission, with the Twist Machine Paddle shifter. It was a used set up so I have had everything checked and freshened up. I did not get a controller. I am now looking at controllers, question 1 is do I have to run the controller from Twist Machine since I have a Twist Machine paddle shifter? (I have no issue with the Compushift just checking my options) If not what controllers can I run?
      The car is a 65 442, I am running a 468 BBO with a carb. What would you guys that have more experience than I do suggest?
      1965 442 "Project Old Mobile"
      Apr 2012
      Woodstock, IL
      You can pretty much run whatever you want with Twist Machine. We use Baumann aka US Shift, they're less expensive than most but work great. PCS, MSD, Compushift etc all are good as well.
      -Dale
      SchwartzPerformance
      west michigan
      I just got the tci setup. Havn't installed it yet but hopefully in the next couple weeks.
      Chad Read
      Dec 2008
      Detroit
      Quote Originally Posted by CRead01 View Post
      OP, check with Steve. I'm not sure if his paddles work with the TCI Controller. As Dale said Baumann , PCS and MSD are cheaper alternatives to Compushift.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
