    Results 1 to 20 of 24
      Jonesboro, Arkansas
      6 speed trans question
      Can a 6 speed transmission be used with the old style clutch linkage instead of the hydraulic setup? I'm thinking of trying to find a 6 speed to put in my 68 Camaro, and sell my Muncie M22 to help fund the switch. Just hate going through the whole setting up the hydraulics.
      Carl Wilson
      Feb 2014
      I have seen it done using the adapter plate on a muncy patterned bell housing. You would need an extended pilot bushing to do it as it backs the trans out.
      Jonesboro, Arkansas
      Clutch would be the same as old style? So, you wouldn't have to use the hydraulic system? Doesn't seem like too much of a problem. I also believe the trans tunnel has to be cut (enlarged). Has anyone done this before? (old style setup)
      Carl Wilson
      Aug 2005
      Hamilton, NJ
      I have the stock clutch and bell housing in my 77z28. I used a McLeod adapter and an extended pilot bushing. You can also get an adapter bell housing from QuickTime and mechanical linkage.
      Scott from NJ.
      Vent Windows Forever! ...
      Mar 2014
      Mesa, AZ
      If you got a 6 speed like a Richmond ROD it would install using all of the stock Muncie pieces, only the cross member and maybe the trans tunnel would need to be modified. If you want a Tremec it's going to take some more work.
      Nelson
      Dec 2010
      Fredericksburg, VA.
      I'm running the stock 1st gen F body Z bar clutch linkage with my Quicktime bell housing and T56 Magnum. Clutch works exactly the same as it did with my four speed in fact it is the same clutch. You will need a different trans crossmember, a throwout bearing snout for the front of the transmission and the drive shaft will need to be shortened with a different trans yoke. You may also need to clearance the trans tunnel but as for the clutch it works fine.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jonesboro, Arkansas
      Thanks for the information guys. Really not as bad as i had feared..it sounds like.
      Carl Wilson
      Jonesboro, Arkansas
      Hey Steve,
      You used a Quick time bell housing, did you have a LS T56? Mine being a LT, T56 if I'm reading this right wouldn't need the special bell housing. My engine is a early SBC, with a 2-piece rear main seal, so i'm thinking i'll need a different flywheel. Above you mentioned a throwout bearing snout, what is this? And do you have a line on the rear cross member? Sorry to be a pain...
      Carl
      Carl Wilson
      Dec 2010
      Fredericksburg, VA.
      Carl,
      Like I stated in the other thread my T56 Magnum is the LS version. I know there is a conversion LT flywheel/clutch that will bolt up to an sbc and supposedly allows the use of the LT version T56 but I hear it is very spendy and I have no experience with that setup so I cannot tell you if it will work with the Z-bar linkage or if you would need to convert to hydraulic clutch. Here is another thread discussing this very topic. The throwout bearing snout or retainer is the collar that shrouds the input shaft and bolts to the front of the transmission and is where the throwout bearing slides fore and aft. The transmission cross member can be purchased from any number of vendors like Speedtech, Hooker, American Powertrain, etc.
      https://www.pro-touring.com/threads/...for-an-LT1-T56
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Reading, PA
      A T56 Magnum with the QuickTime RM-6023 PB bellhousing is one recipe to use mechanical clutch linkage.
      Jody Haag
      [email protected]
      Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
      610-413-8015
      Jody's Transmissions on Facebook
      Jonesboro, Arkansas
      Don't give up on me yet Steve....lol
      Carl Wilson
      McCleod has an adapter plate for using an earlier bell with a T56. Another possible solution
      http://www.summitracing.com/parts/mc...FQczaQodKmgDZg
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by JodysTransmissions View Post
      Jody, Can you give Carl an idea of what is involved in converting his LT1 T56 to an LS configuration?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Jonesboro, Arkansas
      Steve,
      Jody pm'd me and said he didn't have the parts I needed.
      I found a place on line that sells everything I need called The Gearbox. I haven't heard of them but that doesn't mean much, I haven't heard of any of these places. I'm doing the LS swap like you suggested. I think it would be my best route... Thanks for the help. I may be calling you later after I get started.
      Carl
      Carl Wilson
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by minendrews68 View Post
      Steve,
      Carl
      Just make sure they understand you need a 1 1/8" 26 spline input shaft.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Walla Walla, WA
      Steve,
      Carl
      Also make sure that you know the first gear ratio of your LT1 T56 and order the right input shaft - some were 2.66, some were 3.36s (and there may even have been some 2.97).
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Boonville, Missouri
      Call Hurst - GMJim was was working on the sleeve set-up that is required to work with the T56 Magnum and the mechanical linkage. I pretty sure it's been release for production.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Jonesboro, Arkansas
      On the earlier T56 trans ( not the Tremac version), how do you check thrust play on the input shaft? I just changed the input shaft, the trans is rear end first in a five gallon bucket. Im going to put the bearing plate on tomorrow and check input play. Can I do this with the trans in this position? I think the play is suppose to be 0.000 to 0.002 if memory serves me right.
      Thanks Carl
      Carl Wilson
      Jonesboro, Arkansas
      On the pilot bushing (extended) do you guys prefer the bushing or bearing? I bought the bearing from Summit, but I'm worried about the possibility of messing up the end of the input shaft if something goes wrong.
      Carl Wilson
      Jonesboro, Arkansas
      I finally got my trans in (yea!), I've got to get my drive shaft cut down tomorrow. I was hooking up my wiring today and thought I'd check out the reverse lockout solenoid. I hooked up a hot wire to simulate a working scenario. The shifter was off and I could see the inside, when I put the power to it the solenoid it clicked, but didn't move. Was it suppose to? I've read that a lot of people tie the solenoid to the brake light wire, is this a good place to pick up power? Just seems like it would wear the solenoid out hitting the brake as much as we do.
      My plans are to do a write up about how this build was accompolished for anyone else that wants to do this. I've had a lot of help with this and credit will be given.
      Carl
      Carl Wilson
