    Results 1 to 7 of 7
      Feb 2012
      Mocksville, NC
      Fuel Injector ID
      Need help identifying these injectors. They are Siemens Deka injectors, there's a 42 on one side and on the other side is a part number I can barely make out. Last 3 numbers are 405. They are black with gray bottoms. I've checked the part numbers list and mine's not on there. These are several years old and they may have changed part numbers. I'm assuming the 42 on one side could be the lb rate? Thanks.
      1968 Charger R/T, EFI,SC,6-speed
      Miami, FL
      Are you sure they are Siemens? Black and gray sound like Rochester/Delphi. Can you post a pic?
      Feb 2013
      South Carolina
      Picture would help.
      I design fuel injectors for SMP and have an extensive database on-hand. Even a partial part number might help with the identification.
      BTW, only an aftermarket supplier would print the injector flow on the part and even then it is rare. 42 is not likely a reference to flow.
      Feb 2012
      Mocksville, NC
      Here's a few pics. The part # is F111405.
      Miami, FL
      Feb 2013
      South Carolina
      We never matched that particular injector. I can help you with comparable flows/part numbers if you need them.
      Feb 2012
      Mocksville, NC
      Yup, that's the info I need. Thanks again!!
