Thread: Pro Touring GN suspension
- May 2010
- Houston, TX
- 14
I have an idea for my car and I just want a few second opinions. I lurk and read here a lot, which has helped me get ideas for my car. Long story short, I have a Grand National that I've had since I was 15. It has seen good days and bad days and was my daily driver up until a few years ago. I was rearended last year and the frame was damaged so I took it as an opportunity to do the frame-off restoration/mods that I've always wanted. Its no longer my daily driver but it's my only "fun" car so I want it to do everything.
My goals for the car are to be a street car that is at home on a road course, autocross course, and the drag strip. I want to the car to look low and aggressive. I want to do as much of the work myself as possible. I love making something or repairing something and the feeling of accomplishment. I also can't afford to pay someone to do everything I want. I want to be a little different while keeping the soul of the Grand National intact.
Frame: My ideas so far are to box and strengthen a spare GN frame that I've obtained. I have seen several examples of how to triangulate the rear shock towers and run tubing from the front cradle area to the rear. I'll try to add as much strength as possible without adding too much weight. I like the speedtech A-body frame kit and I'm hoping they make one for a G-body before I get this far. I can weld a bit so I'll tackle this myself or at least as much as I can. I'm fairly confident I can handle this or can at least learn what I need to know.
Front Suspension: I'll go with SPC upper/lower a-arms and AFX spindles for the front. I already have the upper SPC arms and Howe ball joints. I have all new steering linkage as well. I like the new speedtech coilover mounts that weld to the frame so I'm leaning towards those and a set of viking adjustable coilovers.
Rear Suspension: Here is where things get interesting. I want the car low and while there are bolt-on products that help with bind issues, the 4-link on the G-body isn't the best. My idea is to get a 4th gen f-body 12 bolt or 9" set up for the torque arm provisions with g-body lower control arm mounts welded on. I get to keep part of it using stock replacement stuff and eliminate the main problem, the upper control arms. I'll fab a crossmember for the torque arm and run a fays2 watts link. That will give me a better set-up for my jack-of-all-trades goals and let me lower the car quite a bit. Plus I don't think its been done before or at least isn't common. If I'm having the 12 bolt rear end built I've thought about having big ford axle tube ends welded on to elimate c-clips and allow more brake options. I think UMi's rear coilover kit with Viking shocks will go well here.
