      Sep 2008
      Farmington Hills, MI
      LS Rectangle Port Heads
      821 heads. 4-5 hours dyno time only. New valves and PSI 1511 springs.
      $825 +shipping
      Michael
      79 Caprice - Iron LS2, [email protected]
      Engine builds in the works..
      Mar 2013
      Las Vegas
      Ls3 or L92? Asking because I wanted to know if they are the badass LS3 lightweight valves or if they are the L92 valves if the valves you installed were stock. Not a bad deal on the heads either way with them coming with the upgraded springs installed. What are the specs on the springs and what retainers? Titanium? Have the heads been milled? Rockers?
      69 Camaro - LS7 441ci ;wet sump, Custom cam, Port matched MSD intake, ported 90mm TB, Texas Speed PRC 285cc LS7 heads withBTR rockers. Tick built T56. Scott Mock subframe, TCI torque arm rear setup, C6 Z06 brakes, built ford 9" 3.73 gears, Trueforged 3pc Wheels. Lots more
      Sep 2008
      Quote Originally Posted by 1nastyZ06 View Post
      Solid valves. Steel retainers. Google is your friend for full spec on the PSI 1511 springs, but they are comparable to a Comp 918 . 130#@1.8 installed height, 370-ish #/in rate off the top of my head. They have been cut, no rockers mentioned or pictured....sooo.
      Michael
      Mar 2013
      Las Vegas
      Don't understand why the attitude was necessary. Sometimes sellers forget items that are included so they don't end up on the for sale thread by accident. Details were missing already so I don't know why it seems like such a crazy idea that I would make sure thre weren't other details missing. Well anyway
      Good luck with sale.
      Sep 2008
      Monday Bump.
      Michael
