    Page 1 of 7 1 2 3 4 5 6 ... LastLast
    Results 1 to 20 of 130
      Port Richey Fl
      1966 Mustang Coupe Restomod
      This is what we are starting with. There is not a lot of rust but since Ford did not prime a lot of the inner structure we will be removing all the sheetmetal do any needed rust repair and epoxy priming. The plans are to install Rod & Custom front and rear suspension, Wilwood brakes, Currie 9", AOD and a 347. The body mods will be fender flares, drip rails removed, cowl vents filled in and maybe a few other things as we go.
      One of the first things we did after bracing the body was to remove the cowl
      The quarter panels were removed
      The roof was also removed and there was only surface rust but in a few years it will get worse if it is not cleaned up now
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
      Beach Park IL
      If the unprimed inner structure made it 50 years, what will happen in the next few? Was the roof rotted so you were removing it anyways? Serious questions.
      Donny
      Apr 2015
      Burlington KY
      wow looks like my car- guess i need to post my project
      Port Richey Fl
      We did not see any rust but we did find rust as you will see once we start the repair.
      Rusty Gillis
      Port Richey Fl
      I'm sure a lot of you are wondering why do we remove all the sheetmetal. The quarters were replaced at one time and we did not trust the workmanship and once they were removed we found rust in the outer wheelhouse. The roof was removed because Mustangs are known to rust in the inner structure in the front by the top of the A pillar. In this case we were lucky and only had surface rust but over time would became holes. The other area on coupes is the sail panel inner structure and we did find rust. A little rust on the left side but the right side had a few small rust holes starting.
      Rusty Gillis
      Port Richey Fl
      New firewall and cowl was sanded and epoxy primed
      The cowl side panels and A pillars needed to be replaced
      Test fitting
      Rusty Gillis
      Apex, NC
      Hey Rusty! Good to see another Coupe project . How have you been?
      Port Richey Fl
      Quote Originally Posted by Crestronwizard View Post
      We have been very busy and it is hard to find time to work on my projects.
      Rusty Gillis
      Port Richey Fl
      Ready for epoxy primer
      Two coats of SPI black epoxy primer
      Rusty Gillis
      Port Richey Fl
      Lower cowl welded in place
      The welds were ground down and epoxy was brushed on
      Upper cowl fit and welded
      Fender apron to cowl extensions welded in place and started to test fit the roof after it was sanded and the back side epoxy primed
      Rusty Gillis
      Beach Park IL
      Nice! Will there ever be a source for new coupe roof skins?
      Donny
      Port Richey Fl
      That is a new Dynacorn roof and NPD has one but it does not have the side panels
      Rusty Gillis
      Beach Park IL
      Well shoot, Is that new? I had looked a while back and there wasn't anything readily available, glad it is now!
      How does it fit?
      Donny
      Port Richey Fl
      Brian has done a lot of work since I last posted
      The rear frame rails had a little rust and needed to be replaced
      Test fitting the trunk floor and gas tank
      Plug welding the trunk drop offs
      Fitting the rear package tray and sail panels
      The quarter panels were shaped wrong and had to be modified
      Fitting the taillight panel and end caps
      Left outer wheelhouse welded in place
      The right side was to long and had to be modified
      Starting to weld the sail panels
      Rear panel welded in place along with the sail panels
      Rusty Gillis
      Man....what a labor of love.
      Port Richey Fl
      The quarter panels, roof, rear deck panel and taillight panel lined up and welded in place
      Rusty Gillis
      Port Richey Fl
      The drip rails were removed and welded
      Welds ground
      We still have more work to do inside the car but to stop the surface Brian sanded it down to bare metal
      I sprayed two coats of SPI black epoxy and it is back in the fab shop
      Rusty Gillis
      Port Richey Fl
      Brian is welding the rear floor and modifying the inner wheelhouse for more tire clearance.
      Rear bulkhead panel welded in place
      Welds ground and interior sanded and ready for SPI epoxy
      Rusty Gillis
      Port Richey Fl
      We had a major set back. Brian lined up the doors but when he went to line up the fenders and hood he found a major problem. A former employee welded the front end on wrong even though he measured and remeasured before welding. There was very little gap on the left door and a large gap on the right side so the front end had to be cut off. After working on this about two weeks at my expense Brian is satisfied with how it lines up and we should be able to start charging the customer again early next week.
      The replacement outer torque box had to be modified to get it to fit.
      Rusty Gillis
      Sep 2013
      sw Kansas
      ^^^ I hate it when that happens!
