      Houston,TX
      LS Parts Cleanout Sale
      Cleaning out all the LS leftovers, it all needs to go so open to any and all fair offers.
      -- Like New Texas Speed and Performance Torquer V2 Cam. 232/234 .595"/.598" Camshaft, used but in great shape with less 500 miles on cam. Was pulled to swap in a blower cam on a 6.0 that received a supercharger.
      http://www.texas-speed.com/p-1149-te...-camshaft.aspx
      $265 +SHIP
      -- New ls3 corvette AC compressor (#89019337), AC bracket (#12569286), Idler pulley (#12560345), AC belt (#12579228), and all hardware. Basically everything needed to add AC to stock ls3 corvette accessory drive.
      $325 +SHIP
      -- Clean set of used LS valve covers, removed from 04' LQ4 with 40k miles, complete with bolts and gaskets.
      $40 +SHIP
      -- Clean used 04' LQ4 intake assembly. Includes fuel rails, stock injectors, and intake bolts/gaskets. DOES NOT INCLUDE THROTTLE BODY THAT IS PICTURED OR ANY SENSORS. Otherwise No cracks or problems.
      $60 +SHIP
      -- Clean low mileage dry sump ls3 & LS7 harmonic balancer.
      $65 +SHIP
      -- Complete accessory drive off 04' lq4 w/ 40 k miles. Came off a running truck with no issues, no leaks, weird noises etc. Bolt on and ready to go
      Includes:
      -Front Balancer
      -AC Compressor w/ bracket, bolts, & belt
      -Water Pump/thermostat housing, thermostat, & bolts
      -Alternator
      -Tensioner
      -Power Steering pump, pulley, & bracket
      -Main accessory drive belt
      $300 +SHIP
      -- Used LS3/L92 head rocker stand GM # 12600936. Was removed from a low mileage 6.2.
      $5 +SHIP
      --LS1/LS2/LS3/LS7 GM factory spark plug wires. OEM nicer 90 degree boot version. Removed from a low mileage LS2, complete with all heatshields.
      SOLD
      -- New AP Brand (OEM brand/made in USA version) T56 clutch master cylinder & used but clean clutch master cylinder reservoir
      SOLD
      -- Clean used set of 04' LQ4 coil packs. These are the more desirable version withn the factory heat-sync. Great shape, just a little dusty.
      SOLD
      --NEW takeoff LS valvecovers complete with bolts and gaskets, removed from zero mile crate motor.
      SOLD
      71' Nova - LY6, T56
      Jacksonville, FL
      I will take the plug wires, just pm me shipped price to 91913. Will send the payment paypal again.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Mar 2013
      Las Vegas
      I will take the rocker stand. Do you only have one?
      69 Camaro - LS7 441ci ;wet sump, Custom cam, Port matched MSD intake, ported 90mm TB, Texas Speed PRC 285cc LS7 heads withBTR rockers. Tick built T56. Scott Mock subframe, TCI torque arm rear setup, C6 Z06 brakes, built ford 9" 3.73 gears, Trueforged 3pc Wheels. Lots more
      Houston,TX
      Quote Originally Posted by 130fe View Post
      Quote Originally Posted by 1nastyZ06 View Post
      PM's Sent
      71' Nova - LY6, T56
      Houston,TX
      Plug wires & clutch master SOLD!
      71' Nova - LY6, T56
      Houston,TX
      Added TSP Cam
      71' Nova - LY6, T56
      Houston,TX
      Coil packs and new takeoff valve covers SOLD!
      71' Nova - LY6, T56
