      Nov 2009
      Austin Texas
      Wire size for Alternator
      What size wire should I run off my 140amp alternator to the battery? 4 awg?
      Beach Park IL
      Distance?
      Donny
      Jan 2013
      Cypress, California
      4 gauge should work. That is what I am running on my 160 amp alternator.
      Feb 2009
      muggy midwest
      Unless its relocated to the rear, there's no need for such a large charge wire directly off the alternator to the battery. A better option is a remote junction with the 4ga supply from the alternator. Then, run a 10ga from junction to battery for charging. All other accessories/relay banks, etc. as well as your remote voltage sense wire run off that same junction as well. Hopefully this isnt a 1-wire alternator you're using.....?
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
