      Dec 2008
      Detroit
      Flywheel torquing 3 step...
      I installed my LS7 flywheel, clutch and pressure plate over the weekend using new ARP bolts for the flywheel and pp. I torqued to the ARP recommended spec of 85ft lbs, but I cant remember for the life of me if I did the 3step torque procedure on the flywheel. Should I remove it all and reinstall just be sure its seated evenly?
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jun 2010
      Deployed
      The flywheel center bore has a slight press fit on the crank. The important thing is you tighten the bolts in a cris cross fashion to evenly get it seated. If all the bolts are torqued to 85ftlbs you are good in my opinion. The three step is just progression...3 strip, 5 step, 10 step the same principal. I would be more concerned with a cylinder head.
      Did you run them in by hand to get the shoulders of the bolts in the holes correctly?
      Reading, PA
Size:  104.0 KBSetting up a dial indicator on the flywheel face to read the wobble would be a good thing to do to ease your mind. The industry standard for flywheel wobble is +/-.002" or .004" TIR
      Jody Haag
      [email protected]
      Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
      610-413-8015
      Jody's Transmissions on Facebook
      Dec 2008
      Detroit
      I pressed the fliywheel against the crank with one hand then I tightened them all by hand until I was unable to do so. I finished with the crisscross pattern then tightened to spec once the bolts were flush.
      Chris--
