    Results 1 to 12 of 12
      Feb 2014
      Country Flag: Mexico
      1969 camaro/firebird backspace
      Would a 4.5 backspace work on the front with 2 inch lowered springs on 18 wheel
      Jan 2010
      Sunset, Texas
      Depends in how wide of a tire you want to use.
      Feb 2014
      Rear is 18 by 9 with a 5.25 backspace. 275 40 18 tire
      Feb 2014
      Will that rear backspace work aswhell?
      Feb 2014
      18 by 8 wheel.. 245 40 18 tire
      Jan 2010
      Sunset, Texas
      Not sure if that will work without rubbing in front. I have a 69 Camaro and I plan to use 235/35/18 on front with 18x8 with 4.5 BS and 265/35/18 on rear with 18x9 with 5.25 BS on rear. I'm going a little conservative on tire size.
      Oct 2010
      Sacramento, CA
      You need 4 and 3/4 backspace. I'm running 245/45-17 on 17x8 with 4-3/4 backspace on my 69 Camaro. Slight touch on the frame rail on the inside tire at full lock
      Rick - 1969 Camaro - LS1 driven daily
      Oct 2012
      Fremont, CA
      Yes, it should work, key word is should. All of these cars are a little different, what fits one may fit another a bit differently, no computer helping put these cars together, and in 46 years since they were assembled, "**** happens"
      That being said, my 69 Bird is running 17X9 on all four corners (4 7/8 backspacing) 255/40 in front / 275/40 in rear, the right side front tire touching the frame in a full crank autocross situation, but it's not hurting anything. Measure, then measure again, when you think you it's gonna fit, purchase and then deal with what you got, good luck!
      1969 Firebird 455HO, TH400, 12 Bolt 3:42, 17X9 Snowflakes w/ 275/40R17 Nitto's, Hugger Orange Imron, Aug 1987 Car Craft cover car.
      Jan 2011
      Boston, MA
      Quote Originally Posted by ccmc View Post
      4.5" BS would push the wheel out 1/4" more than yours and lessen the chance of rubbing on the subframe.
      Feb 2014
      I think im going with a 4.75 backspace front since i tought they only offered a 4.5 backspace so a 9 wide with 5.25 backspace is right 3 inchs lowered rear
      Jul 2012
      NOLA
      On my 69 Camaro I'm running 245/40's on 18 x 8 w/ 4.75 BS (front) and 275/40's on 18 x 9.5 w/ 5.5 BS (rear). 2" drop front & rear.
      69LSX
      Oct 2010
      Sacramento, CA
      Thank you, I know but then I would be into the fender and I seldom hit full lock except in parking lots at low speed
