      Feb 2006
      San Diego, CA
      '67 Firebird. . .beginner Auto-X set-up; thoughts/suggestionsconstructive criticism
      I'm trying to do a small update/improvement to my '67 Firebird 400 coupe's suspension while I have it apart and getting it road worthy; I would like to start Auto-X'ing it as well (there are a few road course events around I just found out about also). I bought the car back in '99 while I was home on leave. . .and it has been in storage since then while I was traveling courtesy of the USN. The plan is to run the local Auto-X events with the small, generally inexpensive improvements until my driving skills improve. Once my driving has improved enough I will be looking to upgrade to the DSE UCA/LCA's and spindle along with a 3-link/Watt's link in the rear and coilovers all around.
      Right now I have an Energy Suspension Hyperflex polyurethane bushing kit, aluminum body mounts (I machined them myself from measurements I took off of the bushings in the Energy Suspension kit), I'm picking up 17" Camaro SS wheels ('97-'02 style. . .like the ZR-1 wheels) with sticky rubber tomorrow, and I got the stock parts to upgrade the front to disc brakes (it's drums now). I'm hoping to order DSE 3" drop leaf springs, DSE 2" drop 650 lb. coil springs, and DSE 1 1/8" front anti-sway bar, and probably go with the Koni adjustable shocks front and rear. It would be nice to fix the front geometry while I'm at it, but I can't afford the DSE or ATS AFX spindles right now with all the other stuff that needs to get taken care of. I was gonna do the Guldstrand mod, but DSE recommends the factory mounting points for their UCA/LCA's so I'm not going to do that anymore.
      I see that CPP offers a spindle that they claim is an early AFX spindle for $269.00 (how I don't know???) and the ridetech spindle would be in my short term price range as well, but the ridetech spindle is only compatible with aftermarket tubular control arms while the AFX spindle will work with the stock control arms; I know RideTech is respected on this forum and they test/torture their stuff. . .I'm just curious what the deal is with the CPP AFX spindles. . .the catalog says
      The
      early AFX body tall spindle
      helps with improved geometry
      by giving a better camber
      change during suspension
      movement and also maintains the
      drum brake offset.
      What do you guys think as far as a beginner goes. . .I have been Auto-X'ing one in a friends Mitsibishi EVO IX MR and it was AWESOME, but my driving skills need definite improvements before I drop money on a big brake kit, 18" wheels, and a full front/rear suspension.
      Thanks for the input!
      '67 Pontiac Firebird 400 RA
      http://www.lateral-g.net/forums/showthread.php4?t=7693
      '97 Camaro
      '00 Yamaha R6
      '01 Aprilia RS-50
      '02 Yamaha R1
