      Feb 2011
      power steering cooler
      hopefully i got this in the right spot. i was looking for advice on power steering coolers... i had a few questions
      1. i've seen two different styles, some like a rad and others are like a bar with a heat sink, any advantage to one style?
      2. does size matter, usually when looking at a cooler for a trans, the bigger the better?
      3. mounting location, do you mount them in front of the rad to grab air flow?
      my car is a 84 monte ss, ls swap with f-body accessories and pump
      thanks,
      steve
      Central CA USA
      I've used the round tube & fin type around 8" long with the tube going down and back up, put ahead of the radiator. Works great and it is plenty for a pro-touring car.
      Feb 2011
      Central CA USA
      I've used this one, it's a little longer. http://m.summitracing.com/parts/hda-1010
      The Dralle might be ok, it's a tiny bit on the smal sidel, but any cooler at all really helps bring temps down a lot.
      Feb 2011
      Quote Originally Posted by David Pozzi View Post
      Sounds good. Thanks
      Mar 2012
      So Cal (818)
      Im running that same cooler with Much lower temps. I also have a Lee finned reservoir. Very happy with the setup
