      Mar 2015
      So Cal
      New guy with a 67 Firebird Pro Touring project
      Hello Pro Touring Nation, I've been searching through these forums as a non-member, but now that I am moving forward with my poor man Pro Touring project I figured it was time to become a member.
      I hope I can provide information for any other 1st Gen Firebird/Camaro owners. I know I will be doing a lot of research and asking a lot of questions on this website so im hoping you guys are patient enough to put up with me.
      Im located in So Cal, San Bernardino County. My name is Osvaldo Barboza most people call me Ozzie.
      My Firebird has:
      Original Pontiac 400 with a Butler Performance 463 Stroker kit
      TH400 3000 stall converter
      Total Cost Involved Subframe
      Wilwood 13" rotors 6 piston calipers
      C5 Rims
      Projects I need to finish before car will be driven:
      Mini Tub car for 315 tire, with leaf spring suspension, so i need to relocated the leaf spring perches, relocate shock location inward, and narrow the gas tank.
      Weld tabs on TCI frame for pontiac motor mounts because the TCI frame is designed for SBC, BBC, and LS1 engines, then powder coat frame and suspension components.
      Purchase IDIDIT steering column and universal steering joints
      Clean up the undercarriage and spray with new undercarriage product
      Clean up firewall
      Custom wheels for 275 front and 315 rear.
      Run new Fuel Lines and Brake Lines
      Purchase RobbMC fuel pump
      As far as body and paint, I will leave it alone due to low funds. Hence the "poor man Pro Touring" title.
