      Jul 2012
      Mooresville, NC
      LS3 fuel rail removal
      I am removing my fuel rails so that I can remove the "sound cover" over my intake and have it painted and reinstalled. Pretty straight forward job, however, there is a bracket mounted on the rear of the driver side head which had to be removed so that I can get the OEM rail assembly off. Like always I question why Chevrolet puts things like this in place to make our life more difficult. Regardless, to remove the bracket I had to remove the two rear intake bolts.
      My first question is....can I purchase two new bolts and retorque them without worrying about an intake gasket leak? The engine is brand new with <1,000 miles on it. As long as I dont remove any more bolts I dont see why this wouldnt work, but I wanted to run it by people with much more experience than me.
      My second question is.....would it be okay to reuse the fuel injector o-rings? They came out pretty easy and appear to be in good shape. I am sure there are others that have experienced this same exact situation.
      Thanks for the help!!!!
      Beach Park IL
      Just reinstall the bolts and torque to spec, 89 inch/pounds and yes you can reuse the o rings.
      Donny
      Jul 2012
      Mooresville, NC
      Thank Donny!! I always thought that the intake bolts stretched and could not be reused?
      Beach Park IL
      I've done it a bunch of times and haven't died in fire yet.......
      Donny
      Apr 2012
      Woodstock, IL
      Same here.. Reused a lot. Head bolts are a different story ;)
      -Dale
      SchwartzPerformance
