    Results 1 to 1 of 1
      Lawrenceburg, TN
      Accel Performance Fuel Injectors
      Accel 151880 - Accel Performance Fuel Injectors
      Accel#110-151880
      Fuel Injectors Flow Rate: 80 lbs/Hr @ 43.5 psi
      Type: USCAR (LS/UNV)
      Impedance: 11-18 ohms
      8/pkg
      These run about 350 bucks...500 from Accel...look them up...there BRAND NEW...letting go for 200 bucks flat shipped to you
      never used...hell I only removed this one from the box for the pictures
      FEATURES & BENEFITS:
      • Provides precise control of fuel delivery and atomization for increased power and improved throttle response.
      • All-new units, not modified stock units or re-manufactured from used cores.
      • Operates at higher fuel pressures without loss of metering control. Great for blown applications, where increased fuel pressure and precise metering are required.
      • State-of-the-art manufacturing processes reduce flow deviations between injectors to improve performance.
      • High-Impedance design for greater control with OEM type ECMs.
      • New anti-plugging type, which will forever eliminate problems that were once associated with carbon buildup.
      • Perfect for Blown/Turbo applications where increased fuel pressure and precise fuel metering is required.
      • For all Port Type EFI Manifolds.
      • 3 BAR (43.5 PSI) Flow Rating - 15% More Flow @ 58 PSI
