    Results 1 to 9 of 9
    Thread: Holley Hydromat
      Jun 2005
      Lynnwood Wa.
      Holley Hydromat
      Just received an E-mail from Holley announcing the release of the HydraMat on May 1st.
      Prices start around $200.00.
      https://www.holley.com/products/fuel...39ad-264498001
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      marina ca
      Pretty freakin cool
      Feb 2011
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Jun 2009
      Southwest Florida
      Nice, I plan on running efi in my pontiac eventually and wanted to use a stock tank so this might work out. This basically replaces the sock right? Holly says that they should last 10-15 years in service before needing to be replaced, though I wonder how true that is considering a stock fuel pickup sock can get clogged in that amount of time, and this seems like it has finer pores.
      -- Dan
      Florida
      Dan, I'm going to try a Hydromat in my bird since I'm still using a stock tank also. Previously I had to keep more fuel in the car on road courses than I wanted in order to keep from sucking air. The original '70 tank and the sock on my pickup were perfectly clean after all the years. I do run a canister filter before the inline electric pump also.
      Apr 2010
      Pittsburgh, PA
      Nice,
      This with a fuelab intank power module and electronic FPR would be a great combo as an alternative to the aeromotive phantom/voltage pump rugulator and flowworx/pressureworx setup
      Most likely the cheapest out of the 3 while supporting the most HP
      72 buick skylark
      Rolla, MO
      May have pushed more towards EFI on my trans am. Looks pretty simple and straightforward.
      Jun 2009
      Southwest Florida
      Sweet John, let us all know how it works out, pretty sure my sending unit is bad so I might go ahead and replace that and the tank, if these are what they're cracked up to be I'll install one at the same time.
      -- Dan
      Florida
      Quote Originally Posted by Yoda4561 View Post
      If it works as well as it looks like it does in the videos from SEMA I'll be very happy. Been trying to find ways to get back the 200Lbs I added putting in the full cage. Less fuel =less weight and as a bonus, less fuel for a fire in the worst case scenario.
