    Results 1 to 9 of 9
      Feb 2013
      Charlotte, NC
      LS3 with no throttle response
      I have an LS3-480 in a 66 Chevelle. Yesterday I drove it about 10 miles to The Home Depot no problems. Got in to return home and cranked engine but had no throttle response. Turned off ignition figuring the computer needs to reset, reboot or whatever it does. Re-cranked car and everything was good. Made 1 more stop on the way home and throttle was good on start-up. Drove it home and put it up. Today cranked the car to find no throttle response. Went through the same drill again but it took 2 re-cranks to solve problem. Driving down the road coasting up to stoplight and no throttle response with engine still running. Got it back home finally with no other issues. Any Ideas???
      Mountain Springs, Texas
      Is the check engine light on, assuming you have one? Did you check for codes? That would be the first step for me.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Apr 2012
      Woodstock, IL
      Hey Art-
      We've encountered a similar issue.. where it was traced to a loose pin on the engine computer, one of the drive-by-wire connections. That seems to be a culprit with some other people. I can't tell you the specific pins to check.. but GM Performance tech support may be of assistance. I've seen this problem pop up a few times on forums so I would imagine someone at GM knows the answer!
      -Dale
      SchwartzPerformance
      Feb 2013
      Charlotte, NC
      Don't have a check engine light Don, but can check codes. Good to know I'm not the first to encounter this. Thanks for the reply Dale. Will be calling GM tech support.
      Wake Forest,NC
      Check the plugs on your throttle body and gas pedal as well.
      Feb 2013
      Charlotte, NC
      Thanks for the reply Tim. Will check those out.
      Apr 2010
      San Antonio, TEXAS
      Had this happen to my cousin in a tahoe, anymore on this?
      2000 Pontiac Trans Am, Ls1/t56, SLP lid, LT's, cut-out, Borla cat-back.
      1980 Pontiac Trans Am, soon to get Ls1/t56 transplant.
      Sep 2013
      Kentucky
      As stated before, it can be a connection issue with the wiring from the ECM to the TB, or an issue with the Pedal to the ECM.
      The codes will help eliminate one of these possibilities.
      Feb 2013
      Charlotte, NC
      Found a loose pin in the connection at the ECM. Repaired that and all seems to be working now as it should.
