      Apr 2004
      Cedar Rapids, IA
      Functional air exstractors
      Has any one messed with adding functional air exstractors to their front fenders to bring down under hood pressure for hi speed driving?
      NY
      I might be wrong, but isn't under the hood a negative pressure area? (cowl induction)
      The needs of the many outweigh the needs of the few.
      Mar 2003
      Kirkland, WA
      I don't think underhood is a negative area, but the area in front of the cowl is a high pressure area.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Apr 2004
      Cedar Rapids, IA
      I had put in a question on another site about building a car for hi speed running. There was a suggestion about putting in functional air extractors to eliminate the high under hood pressure.
      Maybe I should ask the question here. What body mods can/should be done on the first gen F bodies for hi speed road racing. I'm thinking in the 150-160MPH tops.
      May 2002
      Northern California
      I did some (very limited) research on this some time ago and found that the best area for air extraction would be at the front half of the hood, although I remember some had hood vents near the hinge area. I read that some people still had lift with rear ward hood vents. This be for heat extaction more so than hood lift at high speeds. The optimum vent location would be just forward of the air cleaner on 1st gens.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      IL/TN
      also look at ducting the an air intake for the radiator from under the front bumper this way you could block off the grills and any other area that air can enter the under hood area also keep the fender wells in .
      https://www.protouringf-body.com "doing what they say can't be done"
