Results 1 to 12 of 12
Thread: ZL-1 Ram Jet 454
ZL-1 Ram Jet 454
ZL-1 RAMJE 454 196of200
$9,800 obo.
comes with upgraded fuel rail, harnice and tune CD. Also manual. Has 510hp fuel injected. Pump gas 10.5:1 comp
#196 of 200. Hand built, balanced and blueprinted by GM.
The block alone is around $5500 from GM
(They made 427 of the 427ci ZL-1 carberated version)
$22 to 24,000 new. has 1200 miles.
Was painted orange, was in a chevelle show car and he wanted it to look like a # matching block for the shows.
I stripped it back to natural aluminum finish.
Zl-1 based on the 1969 motor. Aluminum heads and block.
Selling due to x wife b.s.
[COLOR=rgba(0, 0, 0, 0.701961)][email protected]
[/COLOR]
71 rs Z-28 ZL-1
02 SS Twin turbo
02-23-2015 #2Price drop- need to sell!
$9,80071 rs Z-28 ZL-1
02 SS Twin turbo
02-25-2015 #3I post specs shortly
71 rs Z-28 ZL-1
02 SS Twin turbo
02-25-2015 #4Tech Specs
All dimensions are in linear inches, except as noted.rated output
Power @ rpm: 510 net hp @ 5,200
Torque @ rpm: 500 lb-ft @ 3,600
Short-Block
Displacement: 454 ci
Bore x Stroke: 4.25 x 4.00
Recommended Redline: 6,000 rpm
Fuel Shutoff: 6,375 rpm
Nominal Compression Ratio: 10.2:1
Block: Chevrolet Mark IV aluminum ZL1 (PN 12370850)
Main Caps: 8620 steel, four-bolt, splayed outer holes
Crankshaft: GM forged 1053 steel (PN 3963523)
Rods: GM forged 4340 steel, 71/416 bolts (PN 10198922)
Pistons: Speed-Pro forged with pressed pins (PN L2465F)
Rings: Plasma-moly 51/464 top, 51/464 ductile-iron second, 31/416 standard-tension oil
Balancer: GM 8-inch-od, counterweighted (PN 10216339
Oil Pan: GM Corvette trap-door style (PN 14091356)
Oil Pump: GM high-volume, 1.3-inch gears (PN 3969870)
Windage Tray: GM new design, Teflon-coated
Cam & Valvetrain
Type: Comp Cams mechanical roller tappet
Grind No.: CBVI 4873B/1498S SR114.0 (custom)
Rocker Arms: GM 1.7:1 roller-trunion (PN 12361330)
Theoretical Valve Lift (Zero Lash): 0.640/0.598
Duration at 0.015 Tappet Lift: 273/276 Degrees
Duration at 0.050 Tappet Lift: 236/232 degrees
Lobe Separation: 114 degrees
Lobe Centerlines: 110/118 degrees
Pushrods: Comp Cams one-piece, 31/48 od x 0.080 wall
Timing Chain: GM single-roller (PN 12371053)
Valvesprings: Dual 1.550 od, 205 pounds seat at 1.900
Cylinder Heads
Type: GM aluminum oval port (assembly PN 12363390)
Intake/Exhaust Valves: 2.25/1.88 stainless steel
Intake/Exhaust Runner Volume: 290/110 cc
Combustion Chamber Volume: 110cc semi-open
Head Gasket: PermaTorque, with preflattened copper wire ring (GM PN 12363414), 9.7cc compressed volume
Piston-to-Valve Clearance: 0.100 at running lash
Fuel & Engine Management
Intake: Ram Jet (PN 12464482, bottom; 12464484, top)
Throttle Body: 58mm 2-bbl., 968-cfm @ 28 inches
Injectors: Rochester Multec disc-style, 12.20 ohms
Rated Flow Capacity: 38 lb/hr @ 45 psi
Operating Pressure: 52-55 psi, 90 percent duty-cycle
ECU: Delphi MEFI-IV
Primary Sensors: MAP, TPS, IAC, MAT, knock
Fluids & Tuneup Specs
Fuel: Premium unleaded, 93-octane preferred
Oil: 5W-30 or 10W-30, 6 quarts (with filter)*
Oil filter: AC PF25 or PF35
Coolant: 100-percent GM Dex-Cool long-life
Operating Temperature: 195 degrees F, 5 degrees
Ignition Timing: 36 degrees total
Spark Plugs: AC R43LTS, 0.045 gap**
Valve Lash: 0.016 intake/0.018 exhaust, "hot"71 rs Z-28 ZL-1
02 SS Twin turbo
03-01-2015 #5To the top,
No balancer or water pump.
Has new flexplate or flywheel for manual trans that's rusted a bit from sitting in my shed.
Has everything else including the
Ecu and harnice and cd, Distributor wires plugs ect.
Also custom billet fuel rail and injectors (and stock one)71 rs Z-28 ZL-1
02 SS Twin turbo
03-16-2015 #6Taking offers.
Will deliver up to 200miles.
Can also pay half shipping maybe more.71 rs Z-28 ZL-1
02 SS Twin turbo
03-17-2015 #7
