      Nov 2010
      corvette accessories
      If you run the 04 style corvette accessories do you have to run the power steering fluid cooler or can you run it like an older car where it goes
      From the steering box straight to the power steering pump?
      Jacksonville, FL
      You can run it without the PS cooler, works great.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Nov 2010
      Awesome thanks!
      Jacksonville, FL
      Something to consider is what kind of line are you going to be using for the high pressure side? If you are going to use a AN6 style line, consider purchasing the fitting DSE sells that allows you to install that line without interference with the pulley. It makes installation easier.
      Chris
