    Thread: 107" wheelbase?
      Crescent City,Ca.
      107" wheelbase?
      Installing a WD front clip,Have pried,beat& pushed.Can only get 107'' out of this without cutting or grinding.Any ideas or will this even be a problem?
      Los Angeles
      I will assume that you are working on a camaro. Is the car sitting on the ground at ride height. The rear end moves for and aft under bump and compression if you are running a leaf spring setup.
      Crescent City,Ca.
      Yes it is a Camaro,its on jackstands under the suspension.No the rearend doesn't move fore and aft on a leaf spring car.The shackles move to compensate for the arch of the rear half of the spring.
      Fontana, CA
      Uhh, not really. During bump the spring flattens slightly, making it longer. The rear shackle moves to accomodate the WHOLE spring movement. When the front of the spring flattens it moves the rear end back a little. It is this movement which requires the play in the Trans-driveshaft yoke. Granted this fore aft movement is not extreme, it does occur.
      Nick R.
      Los Angeles
      You got to it before I could.
      If there is enough space all around and the wheelbase is the same pass and driver then I would not worry about it. The general did not make all of these cars the same. So the 108" is more of an estimate then a cut in stone number.
      Central CA USA
      Higher than stock caster will reduce wheelbase a bit too.
      Jan 2003
      Arizona
      Yup. It's the caster. So the wheel ends up located a bit rearward in the wheelwell. It would be nice if Wayne Due "rolled" the suspension pickup points forward to compensate. I took some of the caster out when I modified my ARDF (pre-Wayne Due) clip. Too much caster for my tastes. Call Wayne and ask if it is reasonable to slot the body mounts. If so, take great care to maintain chassis alignment.
      ________________
      Steve Chryssos
      westchester county new york
      You could make inserts for the slots so the bolt isnt trying to keep the subframe from moving. Would that work? If so you could "tune" your wheelbase a little bit.
