    Results 1 to 12 of 12
      Jul 2009
      Cypress, TX
      VIN tag installation
      The VIN tag was removed from my son's 1969 Camaro during the restoration process, and, of course, we misplaced it. I'd been dreading the registration process, as I figured it would be greatly complicated by the missing VIN tag. Well, good news, I found it this morning. Now, what are the rules regarding re-installing the tag? It's rusty and looks a little dinged up. Can I sand and paint it? Are there special rivets/screws that need to be used? Do I need to get the State involved before I re-install (I'm in Texas)? Any advice you can give me would be greatly appreciated.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Dec 2013
      Jacksonville, FL
      The 69 Camaro came with a pair of rosette rivets. The best thing to do is contact your local DMV for instructions and possible paperwork. I have found that each state can be different. Sometimes you have to visit a local branch and/or have the vehicle inspected. It is less painful than it sounds. Good Luck.
      Mar 2012
      Escondido CA
      Bill is right must get Rosette rivets, you can sand and paint it no problem. In CA my advice is Don't contact DMV! Buy rosette rivets in Ebay and put Vin back on. You are not switching the Vin on to another car or trying to deceive anyone, unless you want the car to be re-vinned with a new non-Camaro number, don't tell DMV!
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
      Miami
      Jul 2009
      Cypress, TX
      Thanks guys! I ordered the rivets. Hopefully, registration will go smoothly and we'll be on the road shortly.
      Jul 2009
      Cypress, TX
      I've seen some discussions about hidden VIN numbers on a car and how they should match the one on the dash. Well, I suppose I should check. Anyone know where they hide them on a 1969 Camaro?
      Sep 2014
      Sun City West, AZ
      I think there may be a body/trim tab on the firewall and it should have a patrial of the vin. As for the secret/hidden VIN, only law enforcement and the super smart thieves will know where they are located.
      Kenny Mitchell
      [email protected]
      Jul 2009
      Cypress, TX
      I would expect that super smart buyers would know too.
      Quote Originally Posted by nokones View Post
      May 2006
      Barrington, IL 60010
      Quote Originally Posted by terrydmorgan View Post
      There are two (2) on the '69 Camaro. One is under the the fan (for your heater) which is located on the firewall under the right fender. The fender needs to be removed to see it...a PITA. The second is easy: it is under the cowl panel on the top of the firewall and to the passenger side of the car. It might be visible thru the cowl vents...otherwise removing the wipers and the four (4) small screws is all that is required.
      Rich
      'Wicked Witch'...1969 Camaro, Mast Motorsports LS-3, Magnum T-56, DSE suspension & BFG Rival-S on Forgeline wheels.
      A herd of stock #'s-matching '69 Camaros.
      Jul 2009
      Cypress, TX
      There you go. I knew somebody would know. Thanks!
      Quote Originally Posted by lzdick View Post
      Dec 2013
      Jacksonville, FL
      http://www.camaros.org/numbers.shtml#PartialVIN
      Here is a quick link to show their locations and a breakdown of what they mean.
      Central Florida
      These won't work for a "VIN" tag (dash area). They are for the body tag ( on the firewall )
      Do a google image search search for "rosette rivet for vin tag" and you will see the rivet for the "VIN" tag
      BB
