    Results 1 to 11 of 11
      Dec 2014
      San Diego
      67 Camaro Ridetech Tru Turn hitting my headers
      Anyone have this issue? I was on the home stretch of my ridetech Tru Turn install, got to the drivers side tie rod and it wont clear the header tube. I have long tube headers on a LT1 in my 67 Camaro. The headers are brand new so I hate to yank them, can I get longer pitman arm and idler arm that would in affect move my drag link bar forward a bit??, I only need about 2 inches. I thought I read somewhere that Camaros have 3 different length pitman arms. Mine currently measures about 5.75 inches center to center. Will it mess up my geometry if I go with longer Pitman? I am so bummed, any feedback greatly appreciated. What headers will clear Tru Turn with a LS1?
      I'm dealing with that whole header issue right now too. You would have to ask one of the ridetech guys but the only fix I have found so far is the dynatech headers. I'm trying to figure out if any one has used any other headers without cutting and moving around one of the pipes.
      Appleton WI
      I have a similar issue using Lemon's BBC headers. I was considering just not using their center link portion of the kit but I'm not sure how well that would work as far as safe geometry was concerned.
      Any ridetech reps care to weigh in on this?
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Dec 2010
      Same dilemma today for me. 1969 camaro small block with Doug's headers. Called ride tech they suggested mid length headers.
      Aug 2009
      Napa, Ca.
      I had the same issues with my SBC and Doug's headers. We ended up having to cut and reroute the header and have them recoated. An unfortunate added expense and 2 weeks of time.
      Works great now though.
      Jeff
      69 Camaro build, body & paint by West Coast Auto Craft
      Build thread http://www.lateral-g.net/forums/show...ght=brownstone
      Lateral-g Feature http://www.lateral-g.net/forums/showthread.php4?t=44186
      Thanks to Matt's Classic Bowties and Pro-Touring.com
      Dec 2010
      Dynatech 740-11310 are suppose to work, with plenty of room.
      Jun 2009
      Tiffin Oh
      Ultimate Headers work great and make good power. http://ultimateheaders.com/
      I'm a dealer if any need them. I helped Jim do the test fitments on many applications.
      May 2002
      Northern California
      surprised they haven't added a note in the product description yet.
      https://www.pro-touring.com/threads/...lling-Tru-Turn
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      If you Google pozziracing.com he's done a lot of research on pitman arm and steering arm lengths as well as a ton of other stuff.
      Aug 2005
      Hamilton, NJ
      I suspect if you start changing parts you'll defeat the tru-turn design intent
      Scott from NJ.
      Vent Windows Forever! ...
      Oct 2013
      Quote Originally Posted by Smittys View Post
      Do you have anything over 2". Your web site says big tube but I couldn't find anything. Thanks
    Tags for this Thread
