      Orange County, CA
      Tire size wheel width help
      Hey, just ordered up some 19x8 and 20x8.5 for my Chevelle. I thought I was going to run Nitto NT555 235/35/19 and 275/35/20. According to Nittos tire chart the fronts are ok, but it looks like the 275 might be to wide for the rear wheel. The reason I'm unsure is that I've seen that same tire size used on the same car/wheel combo twice before and it looked fine. Anybody here run that combo? After searching the 275 it seems a lot of people run it on a wider wheel, but to me the tire seems to be sucked in. I'm looking for a flush or slight bulge to the tire, with equal profile and bulge front and rear.
      Apr 2012
      Woodstock, IL
      Approximately 25mm is one inch. So 12.5mm is a half inch. Add that to your 235 and you're at 247.5.
      I would go with a 245 if you want flush, or 255 for a tiny bit of bulge. The 275 will stick out a bit, though you can mount it on an 8.5" rim.
      -Dale
      SchwartzPerformance
      Orange County, CA
      Thanks Dale. Do you think the 235 on the 8" wheel is a good starting point?
      Apr 2012
      Woodstock, IL
      Yes that's a perfect size for 8" wheels.
      SchwartzPerformance
      Jan 2013
      Bridgewater, NJ
      235 works great on a 8" wheel, 245 for the 8.5".
      We subscribe to the tire width - 1" = ideal tire width. So a 255mm tire (about 10") fits perfectly on a 9" wheel.
      Paul Huryk
      President CTW Motorsports
      1989 GTA - Global West Suspension, Wilwood Brakes, CTW Motorsports wheels, Full Magnaflow exhaust
      1984 Camaro - Global West Suspension, Baer brakes, CTW Motorsports wheels, Mild 350 with nitrous
      http://www.ctw-motorsports.com
