    Results 1 to 10 of 10
      Apr 2011
      68 nova LS1 6 speed
      Item Location (City/State):Los Angeles, CA
      Price:$old!
      Description:
      I have for sale my 1968 Nova, I've been on this forum for while, mostly lurking and learning. I bought this car a few years ago and it has served me without the slightest hiccup. The following description is from the previous owner/builder (forum member here), I didn't change a thing since I've had it....didn't need to it was as close to perfect for an awesome, fast, fun and reliable street machine.
      Body
      -Finished in Lemans Blue PPG base/clear with semi gloss black Baldwin Motion style stripes bordered in vintage white
      -started with completely rust free body with all original sheetmetal (aftermarket steel 4 inch cowl hood)
      -New door and hood hinges
      -All panels gapped perfectly- doors and trunk shut with minimal effort
      -Newer vinyl top with new stainless trim
      -Detroit Speed minitub kit installed- trunk finished with factory style look
      -S&M race cars 8 point cage with camera mount- custom floor plates
      -New mirrors, emblems, door locks, etc
      -Paint is in excellent shape with some minor flaws- far better than driver quality- car is shown and does win paint awards
      -Entire floor covered in Fatmat sound deadener
      Chassis
      -QA1 adjustable front billet coilovers
      -Addco 1.125 inch sway bar with urethane mounts
      -SSBC front brake kit- slotted rotors and billet calipers- Wilwood billet master cyl.
      -Unisteer manual rack and pinion steering system with polished stainless link kit
      -New urethane bushings, new ball joints, wheel bearings etc
      -Competition Engineering subframe connectors
      -Inboarded Eaton Detroit leaf springs using Comp engineering rear mounts
      -Custom rear shock mounts with Comp Engineering adjustable shocks/ custom lower shock perches for optimal shock angles
      -Custom traction bars with adjustable links
      -Custom ordered Currie 9 inch rear diff. with 5 inch narrower track to optimize DSE kit (gives more wheel options and a far wider rear lip) – spine braced, filler cap, drain, vent
      -Strange Pro-G nodular third member
      -Detroit Locker, Richmond 4.33 gears
      -35 spline Moser axles, new bearings and seals
      -Centerline Telstar billet wheels- 15 x 7 (new 205/60/15) and 15 x 10 (Mickey Thompson 325/50/15 Drag radial) The car can run an 11 inch wheel and a 315+ tire. The custom narrow housing allows for a 6 inch deep rear lip.
      Engine
      -2003 LS1 (all aluminum)
      -TEA ported heads
      -Autokraft oil pan
      -Edelbrock motor mounts and coated headers
      -Thunder Racing Trex 2.0 cam (242/248 .608/.612 110 LSA)- new LS2 timing chain-matched valve springs, locks, Ti retainers etc
      -Thunder Racing new ported and polished LS6 oil pump
      -Comp Cams Heavy duty pushrods
      -6.0L heavy duty Coil packs and Taylor plug wires
      -Edelbrock victor intake manifold and custom Holley HP 750 carb built by Competition Carburetion of Nevada
      -MSD 6010 timing controller with easy to use laptop software, custom billet bulkhead harness plate
      -2.5 inch exhaust with 3.5 inch electric cutouts, Bullet mufflers, X pipe, and over the axle terminating under the bumper tailpipes
      -Meziere billet electric water pump with in-car adjustable speed controller
      -Holley blue fuel pump- (-8 delivery line, -8 to carb, Holley reg. with gauge, -8 return line,20 gallon aluminum cell with AN beathers and sump)
      -Custom ordered Griffin radiator with 1.5” tubes (-20 AN water lines, 1600 cfm fan) car runs 175-190 on even the hottest days in traffic
      -T-56 trans with Hurst billet shifter
      -Monster level 3 clutch
      -Billet steel flywheel
      -ARP hardware
      -Custom tubular trans crossmember with drop out center
      -Quicktime SFI scattershield
      -new steel driveshaft by Driveline service with all 1350 Spicer joints
      -Custom billet capped center console/ Lokar boot/ Hurst pistol knob with line lock
      Interior
      -New door panels, hardware, and dash pad
      -Custom built gauge panel with billet gauge surround, billet control panels, Autometer gauges and tach
      -Corbeau race seats, G force 5 point harnesses, custom rear bulkhead panels and package tray
      -New headliner and mirror
      -Painless wiring harness
      -Lecarra steering wheel
      The car can be converted back to PT with a wheel change and a shock adjustment. The previous owner had 17x11s on it with 315s, with the correct backspacing it could probably take 335's.
      I've bought and sold many cars on the "other" forum, please feel free to contact me directly at 818-970-3218.
      I almost bought this car the last time it was on the market for sale! Its a beautiful ride. Why are you selling? I might be interested again if mine sells soon. So you have not done anything to it since you have owned it? I guess I forgot there is no back seat, is this do to the tubbing? Can a rear seat be installed?
      Thanks, Erik
      Beautiful!
      Tom
      Apr 2011
      Quote Originally Posted by Erik Beckett View Post
      Thanks, Erik
      Personal circumstances, I need the space and money. Haven't wanted to or needed to change anything on the car. It is mini tubbed, the tubs wouldn't be an issue for the back seat, but the roll cage bars would be in the way.
      Apr 2011
      Here is a picture from the previous owner with pro touring type of wheels. I believe this is the same picture that's on the Vintage Wheel Works site in the Chevy galleries.
      Apr 2011
      Sorry, double post
      Apr 2011
      BTTT with price drop.
      I want this car bad! I just lowered the price of my camaro on here. We will see what happens.
      Erik
      Apr 2011
      Erik
      Thanks Erik, good luck with your sale. I am open to offers, the worst I can do is say no.
      Apr 2011
      This car is sold, please close.
