    Results 21 to 40 of 53
    1. #21
      I've never driven a car that I didn't feel needed just a little more power...LOL
    2. #22
      Central California
      About half of what I've got ...
      Mary Pozzi
      "STICK, you B*TCH!!!!!!"
    3. #23
      Loganville, GA
      All these replies and no one quoted Donohue: "If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower."
      Like a few said, once you get to 500 hp, you probably have enough. Get the rest of the car to handle that quite well, then you can go for more hp. Just my 2 cents worth.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
    4. #24
      Jun 2012
      South Lyon, MI
      Quote Originally Posted by mpozzi View Post
      Mary Pozzi
      Mary, I'll take what you don't need. I could use a bit more...
    5. #25
      Feb 2014
      I sure wouldn't mind a little more than 170 myself. :-[
      And even now I plan to do the suspension and brakes before I add power... Partially due to emmissions blehh!
    6. #26
      Dec 2010
      It is weight to HP and torque that matters I have a car that puts down 862 RWHP and it is very controllable but it is very heavy, my other car puts down about 725 RWHP and it is almost undrivable at more that 40% throttle opening. First car weight to hp= 4.25 with driver second car weight to hp = 3.50 with driver. Small number but huge difference in drivability
    7. #27
      Dec 2012
      Would be very interesting to hear about the specific details (vehicles, suspension etc.) between the two vehicles
      Cheers
      Steve
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
    8. #28
      Newbury Park, CA
      Having too much power can make the car not much fun to drive. The throttle pedal becomes a tire spinning switch which just wastes everything.
      The other drawback to making big horsepower is the expense. Sure, 1000hp sounds "easy", but to go from 500hp to 1000hp (2x) the right way will cost 4x as much (minimum) in time and money.
    9. #29
      Dec 2010
      First vehicle is a 2005 Ford GT with a 4 liter Whipple running 26 lb of boost, it has an Accufab throttle body, long tube headers, x-pipe, Magnaflow mufflers and 2 MSD fuel pump boosters it has about 59% rear weight which helps traction. front tire 265x18 rear tire 345x19 Michelin PS2. Suspension is independent front and rear with aluminum arms and uprights with modified geometry to improve handling. The car has skirts made from conveyer belt to keep air from entering from the side. It has a 7" extended carbon fiber splitter and a 72" wide GT1 wing at the rear, car was also lowered 2" from stock. The only electronic aid is ABS, It has a full belly pan with diffuser (stock) and very good aerodynamics overall. Car weight is 3470 less driver.
      Second Vehicle is an original 1966 427 Cobra with modified independent suspension front and rear. Geometry is improved over original, weight bias 52% rear. Tires are 315x18 front and 335x18 rear. engine is a 498 CID Shelby aluminum block with moldex crank and Carrillio rods, 15 to 1 compression, blue thunder high rise heads with Ti intake and exhaust valves. Cam is comp with over 290 degrees on both intake and exhaust at .050" max rpm is 8000. engine has a 1650 cfm TB with 65 lb injectors run by a classic fast controller in alpha N. Max crank power 850@7600 max torque 632 @ 5700. Rear end ratio 3:31 with Jerico 4speed dog trans. First gear is 2.2 to help control wheel spin. Throttle is 6" of travel with the first 4" giving 25% opening to help modulation. Car weighs 2370 with all fluids less driver. The body is completely stock with no aero aids other than stock radiator vane.
    10. #30
      Apr 2013
      Louisville, Ky
      It all depends on how you are going to use the car, road course, autocross, pure street miles. one thing that can make some difference is how it's geared. did you mention what your trany is, or ring and pinion?
      Anthony Hammond
    11. #31
      Apr 2011
      Ewing, NJ
      More power is a nice thing but being able to use all the power you have all the time is ALWAYS better. Work on chassis and driver upgrades and worrying about adding power as your wallet allows.
      NJSPEEDER - Tim Mullaney
      New Jersey F-body Owners Association
      www.NJFBOA.org
      NJ's home for all owners, friends, and fans of Camaros and Firebirds
    12. #32
      SoCal
      Quote Originally Posted by sheck44 View Post
      Cheers
      Steve
      Bruce was pretty modest to not mention that one car completely dominated the '09 OUSCI while the other was a top competitor in other years.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
    13. #33
      Apr 2014
      I didn't see anyone mention this, but how you achieve the extra power plays s role. Ie electronics, turbos etc. Guys run 275 drag radial cars now well into the 4 ' s in the 1/8th with turbos and electronics. Street cars w proper sized turbos and proper tuning can make 700-1400 without a lot of hassle.
    14. #34
      Mar 2012
      Escondido CA
      Quote Originally Posted by octane speed shop View Post
      This x2. In an Autocross my 250 RWHP 3000 lb car is very competitive. On a road course its not enough, but 475 RWHP would be plenty...
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
    15. #35
      Central CA USA
      600hp with 200 tread wear tires is a very nice combo for a PT car. You will be well hooked up from second gear & up with pretty good wheel spin control in first if you are careful. With 650 you have to be a lot more careful in first, & second can buzz the tires on the street. Bad Penny with 700 plus at the crank is tougher to hang on to depending on the surface, second gear traction is more like first gear traction in a 600 horse car, wheel spin with just quick throttle application. It requires skill & experience, & is a wild ride. On cleaner pavement like a road course, it gets better. A turbo or supercharged car will have more torque & spin the wheels even more.
    16. #36
      Central CA USA
      Quote Originally Posted by Schwartz Performance View Post
      To be competitive, if you have the suspension already figured out, 600hp is about all you need.
      -Dale
      I like this answer, especially for a truck with less rear weight bias.
    17. #37
      Jan 2015
      Charlotte, NC
      350-400whp if you can make it stick...will certainly hurt lots of feelings, and land you in jail..so that's good for me
      In my opinion, at least
    18. #38
      Oct 2008
      texas
      I was always happy with my bone stock LS1 I think it's about 350 @ the crank. That was until we drove it up to Rocky Mountain national park and pikes peak it was a breathless dog trying to climb in altitude. I knew then why big power and torque is needed lol. I'm still happy with the 350ish @ sea level though.
      This is Larry Callahan adding to Rocky's profile.
      I'm sorry to say that we have lost Rocky.
      RIP....
    19. #39
      Mar 2014
      Burlington, KY
      Quote Originally Posted by rockytopper View Post
      I wasn't a big fan of turbos until I started going back and forth between sea level and the mountains.
    20. #40
      Dec 2014
      Sacramento,CA
      Thanks guys, lot's of great answers and info in here. I am a poor, cheap ******* so I won't likely be running big road course events. Probably the occasional autox. I also like to visit my family who live up in the mountains, as well as the occasional trip to Tahoe to our family cabin. I want a good road machine that I can throw into a corner with confidence, but when I show up at an autox I don't want to look feel a geo metro at the drag strip. I have done much deliberation and I think I have found the ballanced answer for power, cost, and meets my needs.
      I have really wanted FI in my truck. I spent a lot of time as a motorcycle mechanic doing performance builds and dyno tuning and I think that I could do a lot with an FI system. Tht being said here in CA, I have a hard time finding an LS donor for less the $2-3k. Si I have been looking at the late 90s vortec trucks and Tahoes. I can pick up a complete running vehicle for under $1k which leaves me financial room for some mods and a manual trans setup. I will be looking for a 5.3l for my daily driver 2001 gmc though because the current engine has 289k miles on it and has developed a cold knock. :-( but I think staying in that 380-400HP range will be sufficient with some chassis modifications.
      Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
      My build : 68 C10 Short Bed Conversion
